Blown IP-1 fuse
Blown IP-1 fuse
Had a problem with my dash cluster-went dead as well as the heater control and a couple other things...went through the CSM and tried to narrow down the problem...that fuse controls seven ccts...I started with the easiest module to get at and it was the 'Remote Function Actuator Module'...this problem had persisted for about seven weeks and finally I had to do something as it is almost time for heat and DEFROST season...I unplugged the harness and my short cct went away...yahooo.....
The doors lock and unlock properly...there is an internal short within the RFA module...I plugged in another RFA module and there is no short but it won't work with my remote cuz it's a different freq...
Oldscutty72
Dec 28, 2015 01:56 PM
