Any had an Engine ticking problem?
Old Sep 10, 2006 | 05:02 PM
matthew.burgess@yahoo.com's Avatar
Cool Any had an Engine ticking problem?
I Have a 1995 Aurora with the 4.0 northstar, I know a little about engine but I'm not certain on what this noise is. Since its DOHC I know that elimanates a lot because it has no lifters and rods. It sounds like to me a problem with something in the valve train. I'm not positive what this car has under the covers. I know you can not adjust valve clearance because it is has hydraulic lash adjusters but do them things ever go bad? Do you think the noise could be the valve hitting the seat, or maybe a worn sping? I have no clue some help would be nice! Thank you
Old Sep 10, 2006 | 05:52 PM
rockethound's Avatar
if true that it has a hydraulic lash adjuster it sounds like it could be like a flat hydraulic lifter. i don't know much about north stars either but like the hydraulic lifter when they go flat they make a tiking sound. which would make a clearence problem in the valve train.
Old Sep 10, 2006 | 07:18 PM
Yea I think so too
Since the lash adjuster is in the head how hard do you think it would be to change? Should I change one, the four on that side(front) - or do you think all 8? The back 4 four would be a pain.
Old Dec 6, 2006 | 07:53 PM
toonsters's Avatar
I had the same problem
I have a 98 Aurora, and it was ticking. I thought it was the engine ticking, it sounded like valve train noise, but the shop I took it to told me it was a cracked flywheel. I didn't quite believe them so we put the car on a lift and sure enough the noise is comming from the tranny right where the flywheel is. I don't know if this will help you, but that is what the noise was in mine.
Old Dec 7, 2006 | 04:50 AM
Oldsguy's Avatar
Past Administrator
FYI guys, I think they are actually called cam followers. I am not really that up to speed on OHV engines, someone correct me if I am wrong.
Old Dec 7, 2006 | 04:04 PM
Redog's Avatar
A.I.R. tube leaks sound like valve taps
Old Dec 9, 2006 | 02:49 PM
Lifters
Well I had the front 8 exhaust lifters, and oil pump replaced at Cadilliac which cost about $1250 and about a week after that the back head started ticking but i'm not putting any more money in this car it only ticks at certain times so I'm just gonna let he tick. Good luck with yours.
JJSCUTLASS
Oct 25, 2014 08:35 AM
hueveaj
Wheels and Tires
Oct 9, 2012 06:31 PM
klovett
Hurst/Olds
15
May 11, 2012 06:43 AM
mhartley
Jun 7, 2011 08:25 AM
gibbo69olds
Oct 3, 2007 06:39 AM
