dash board electrical short
Old Aug 17, 2006 | 12:44 PM
maj42's Avatar
Occasionally after starting our 1999 Alero (with only 12,100 miles) the radio will not work; on more occasions the radio and power windows will not work; most often, the radio and windows won't work AND the dash board instrument panel is completely dark. In spite of all the above, the car will run! Our temporary fix is to hit the dash board with a fist (only above the the instrument pod). Any suggestions before I go to a repair shop.
Old Sep 21, 2006 | 08:36 PM
Eirik's Avatar
sounds like a bad icm. in a pre 2000 gm vehichle the radio is mostly seperate, it only has a few feed wires from the pcm, but no major data sharing, that started in 2000. sorry.. i used to work trim/electrical for gm
Old Sep 24, 2006 | 04:19 AM
rocket9r8's Avatar
hey guys if he smacks the dash, could it be a loose connection? or maybe a bad ground?
Old Dec 29, 2006 | 01:54 AM
Redog's Avatar
^ yeah but good luck finding that
Old Jan 7, 2007 | 03:01 PM
tjzullo's Avatar
Thumbs up no power
check power at the right hand instrument panel fuse block for power windows when this happens if none replace the ignition swicth.let me know
Old Feb 9, 2007 | 04:22 PM
American Lead's Avatar
2Blue 55
check for loose harnesses, that was a problem in my 2000 ch#vy
Bobac455
May 1, 2021 12:06 PM
Bobac455
May 11, 2010 07:36 AM
erudek
Sep 27, 2009 05:48 AM
maj42
Aug 17, 2006 12:58 PM
86in
Feb 9, 2005 09:49 AM
