Alero? what are your thoughts
I am looking for a cheep daily driver and noticed that I can find Alero's for less than $2500 all day long. Does anyone know what the common problems are after 125,000 miles. I know all the normal things at that mileage but wondering if there is anything common like head gaskets or transmissions that go out all the time?
The 3.4 V6 had issues with intake gaskets. But at that mileage, I would like to think they were replaced with improved metal backed ones by now. Another common problem was the security or passlock issue. There is a bypass, that can be done, just goggle that. Cruise goes out, usually the switch needs to be replaced. Since were in the rust belt, check for rust in the rack and pinion mounting area, engine cradle and rear of the car.
Pat
Pat
Pat
Pat
I have a co worker with one that he bought from his brother for a winter beater. This is winter #2 with it. Brake lines rusted out, and he is fighting the ignition/security issue right now. It sits idle.
03 is the one I want to go look at. I also found an 89 calais International series I am thinking about going to look at but it is a little to much money for what I am looking for
For $2500 you can get an Oldsmobile 88/LSS or Buick LeSabre with less miles and a 3.8l v6. The 3.8l v6 is probably the most durable engine GM ever made. Do a quick YouTube search and you will find plenty of videos that speak highly of them. Check it out!
Aleros
Olds64: Good idea, they are great cars. Many cars came with the 3.8 V6: 1980's Buick Century, Regals, Olds Cutlass Cieras, Add to your full size list Pontiac Bonnevilles, Olds Silhouettes. Silhouettes are plastic clad which might be a plus in New England or Midwest winters. I had a friend with a 89 Calais Quad four that just ran and ran for ever without problems. I like the Olds Achieva, but would find one with a Quad four and stay away from the 3.1 V6. I also have a buddy with an Alero that he reported one problem, likely the leaking head gasket. Maybe 1977+ RWD 88, Caprice, LeSabre, etc might be found in the right price range. So, it depends if you want a smaller and larger car there are plenty of good choices. You said cheap daily driver, not necessarily a smaller car. Regards, Trent in Los Angeles
https://www.youtube.com/watch?v=5lRLmlM8o5Q
Aleros
Greg: Good point, I saw a nice one posted on the east coast for cheap and the seller said it had rust problems and provided good photos. Nice to see an honest seller. I think the shock support along the bottom looked horrible, like it needed a new cradle. Something to check before purchase on any car, I always look on the bottom. Regards, Trent in Los Angeles
Check the cradle on that 98 too. A friend had one of those that was bought new by his since deceased mother and it became so rusty it wasn't safe anymore. He actually junked it and was really bummed because it was such a nice driving car. I don't know how much salt they use in Indiana but here in Michigan salt just destroys our cars.
Bernhard
Feb 5, 2013 10:31 AM
