TVS testing
Old Jun 16, 2013 | 08:22 AM
ddd777's Avatar
TVS testing
How does one test if thermostatic vacuum switch units are in working order?
Old Jun 16, 2013 | 08:37 AM
You stand a better chance of getting a useful answer with your own thread rather than tacking your question onto a five year old thread, so here you are.
The TVS has two parts, the solenoid that switches vacuum off and on based on the trans switch for TCS, and the thermostatic switch that reacts to coolant temp. You can test the former pretty easily by applying vacuum and +12V to see if it switches. The thermal part is a little harder since it opens above the boiling point of water at atmospheric pressure (at 15 psi in the cooling system, water boils at over 250 F). That means you'd have to use a working fluid with a higher boiling point (oil?) to test it.
Old Jun 17, 2013 | 03:33 PM
BlackGold's Avatar
Of course, some failures occur at room temp. No boiling oil required.
Use a vacuum pump on the carb port. At room temp the carb port should be connected to the distributor port: air should flow, you should not be able to draw a vacuum. If you then plug the distributor port, you should be able to draw and hold a vacuum.
Next put the pump on the manifold port. At room temp it should be isolated from the distributor port. No air should flow, and you should be able to draw and hold a vacuum.
The carb port and manifold port should be isolated from each other. And under no circumstance should there be a vacuum leak when you put the pump on one of the three ports while the other two are plugged. That would indicate a leak between the cooling system and the vacuum system.
Old Jun 18, 2013 | 07:56 AM
BILL DEMMER's Avatar
Just the facts...
and to test the thermostatic "switching" function, judiciously apply heat from a lighter, i would not recommend a torch.
bill
pcard
May 2, 2012 04:54 AM
pcard
Tech Editor's Desk
Mar 14, 2012 10:01 AM
jonrare
Suspension & Handling
Jul 2, 2011 06:42 AM
oldzy
Jan 3, 2011 02:38 PM
Chumley
Feb 18, 2007 04:16 PM
