1972 442 w-30
1972 442 w-30
Hello,
No 1.
Is anyone aware of a 72 w-30 having G heads originally put on by the factory? Casting numbers for either a G or Ga head are the same 409100. I have seen an "X" vin 72 w-30 with G heads. Could this be a late '71 build car?
No. 2
Where are the casting numbers located on the Q-jets?
Please advise and thanks!
No 1.
No. 2
More
Hello,
No 1.
No. 2
No 1.
No. 2
What is the build date of the car in question?
The main info on the quadrajet is on the drivers side near the back. should be 7042953 if I remember correctly followed by two letter that are for the pant and underneath that 4 numbers which is the Julian build date.
Follow up.....
OldsDave, Kurt: Thanks for the feedback! Was told that the motor was rebuilt many years ago... higher likelihood the heads were switched at that time.
Joe: Q-jets--> Looking for the numbers that ID the carb's specific application so.... that would be the stamped ID number as you alluded to. I was able to locate a youtube video that helped me find where to look!.... Thanks!
Steven: Thanks! That's the same info from the video!
drtdobber
Jan 29, 2007 08:46 PM
