where can i find the vin# on my dads 69 442 ?
Old Mar 29, 2012 | 06:28 AM
eds69's Avatar
My dad has a 69 442 the vin # is rusted out except for the last for digits that read 0006. Where else did they hide the vin # on 69 442's? Any help appreciate. Please email to bjpenn7@yahoo.com response in addition to posting it on this site
thanks in advance.
Ed in Texas El Paso
My dad has a 69 442 with and the vin # is rusted out except for the last for digits that read 0006. Where else did they hide the vin # on 69 442's? Any help appreciate. Please email and post response bjpenn7@yahoo.com
Ed in Texas El Paso
My dad has a 69 442 the vin # is rusted out except for the last for digits that read 0006. Where else did they hide the vin # on 69 442's? Any help appreciate. Please email And post answer.
Thank you.
Ed in Texas El Paso
Thank you.
Ed in Texas El Paso
Old Mar 29, 2012 | 08:32 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I merged all of your multiple posts into one. Please limit this to one thread in one category.
Old Mar 29, 2012 | 09:42 AM
rcorrigan5's Avatar
Randy C.
Two quick places to look to find what is called the VIN derivative, but you might have to do some cleaning and/or move brackets to see clearly.
1. On the driver side forward part of the engine block, just below the "C" on the forward part of the head, there is a pad where the VIN derivative is stamped. If the engine is original to the car, this VIN derivative will be a rough match to the VIN of the car. If the car has power steering, a bracket goes right across this area and it's hard to see unless that pad is clean and you use a mirror and a flashlight to observe it. A better way is to remove that bracket, clean the pad and read the number. The VIN derivative will look like this:
39(a letter or number, either E, M, Z, or 1)(another number, either 1, 2, or 3), and then 5 numbers. If the last 4 numbers of your dad's VIN are 0006, then the last 4 numbers here will also be 0006 if the engine is original to the car.
2. On the transmission, again if the tranny is original to the car. If it's a manual transmission, the VIN derivative will be stamped into the driver's side vertical surface of the housing (can be seen from under the car - might have to clean off oily dirt first and use a flashlight). If it's an automatic transmission, the VIN derivative is also stamped into the driver side, but on a horizontal surface between two ribs in the housing - it would take a mirror and a flashlight (and some cleaning if it's dirty) to see.
In the end, the real VIN on the dash should appear like this:
344, followed by
67 (if it's a convertible),
77 (if it's a sports coupe - that is, a post coupe),
87 (if it's a holiday coupe - that is, a 2-door hardtop - no post), followed by
VIN derivative, less the 3 that starts the VIN derivative,
and if the numbers 0006 are correct,
344(number)79(letter or number)(1,2, or 3)(number)0006.
Hope this helps.
Randy C.
Old May 17, 2012 | 09:59 PM
FAZ442's Avatar
check the title
The Tin Man
May 12, 2014 04:25 AM
70convert
Mar 21, 2014 07:38 AM
coppercutlass
Nov 24, 2013 02:45 AM
swells
Nov 8, 2011 10:43 PM
MN71W30
Apr 5, 2009 08:18 AM
