Shake
Old Jun 26, 2011 | 05:41 AM
Thomas Simcich's Avatar
Shake
What would cause a manual transmission car to shake and shutter when letting out the clutch?
Old Jun 26, 2011 | 06:51 AM
rocketraider's Avatar
Oldsdruid
It's usually a sign of a worn or weak clutch. Could be clutch disc, pressure plate, throwout bearing, or worst case a warped flywheel.
If it just started, I'd lean toward a weak pressure plate. Either way, start saving your money for a clutch job.
Old Jun 26, 2011 | 06:52 AM
CQR's Avatar
CQR
Bent or warped clutch disc. Hot spots on the flywheel or pressure plate, sticking damper springs on the disc. oil or fluids on the disc, something like that.
Old Jun 26, 2011 | 07:44 AM
Nilsson's Avatar
Clutch chatter and is usually more of an annoyance then a problem in most cases.
Old Jun 26, 2011 | 11:20 AM
Oldsdruid
One other thing to check (and thought about this in church this morning when I shoulda been thinking about Eucharist )- check the transmission and engine mounts. If it's loose or broken, it'll cause the shudder too.
Is pedal freeplay within specs? you want about an inch of free pedal travel before you feel resistance in the clutch linkage.
Old Jun 27, 2011 | 12:05 PM
scubastever's Avatar
this is not my car lol
true. your clutch disc can have lots of "meat" left on it, but if your flywheel is covered in hotspots- you'll get a chatter.
you can remove the flywheel and have it machined to resolve the issue.
Old Jun 27, 2011 | 04:45 PM
I would check freeplay as mentioned above!!
Old Jun 28, 2011 | 03:53 AM
rustyroger's Avatar
'87 Delta 88 Royale
Have a look at the rear end mountings while you are under the car checking the engine/trans mounts.
golds56
Aug 26, 2012 09:23 AM
XMWZ001
Drivetrain/Differentials
May 19, 2012 06:54 AM
wikkonado
Jun 15, 2010 09:27 PM
johnfharding
Ninety-Eight
Dec 25, 2008 08:20 AM
