455 oil pan swap
455 oil pan swap
I need to change the oil pan on my 71 442 because somebody in the past decided to jack the car up with it. I have a 71 shop manual and it says that you have to pull the tranny to get the oil pan out. Please tell me this isn't so can I replace it by undoing the motor mounts and lifting the engine up?
The risk in complete removal is that while it's out, you MIGHTASWELL replace the oil pump and you MIGHTASWELL do the timing chain, and... well, you understand.
