1966 442 Intake Valley Pan Installation
Old Aug 11, 2010 | 10:14 AM
cessna195's Avatar
I will be in the process of assembling my 1966 442 400cu engine and I am wondering if there is anything special I should do when installing the intake manifold and pan or just follow the instructions that came with valley pan?
John
Old Aug 11, 2010 | 12:05 PM
Run to Rund's Avatar
Spray the intake gasket with permatex copper sealer. Use ultra black rtv at the water passages and use rtv instead of the front and rear rubber seals. Be sure the coined protrusions fit into the corresponding holes in the heads when positioning the gasket. Tighten the bolts in factory order in steps. After running, let it cool and retorque.
Old Sep 3, 2010 | 12:22 PM
coolstreak's Avatar
Where did you get a new valley pan? OPG doesn't carry it. Or can I straighten up my old one and re-use?
Old Sep 3, 2010 | 01:13 PM
Do not attempt to reuse the old gasket. The bead around each port is crushed during installation, which is how it seals. Once crushed, they will not seal again. FelPro sells the gasket, available at any auto parts store.
Old Sep 3, 2010 | 04:25 PM
coolstreak's Avatar
sure, joe, i should have known that . . . . THanks for the source of a new one.
Old Sep 5, 2010 | 09:16 AM
68442CONVERTCO's Avatar
Aloha, Tony
John,
Be sure to get someone to help you. If you are using the stock intake, it weighs a ton!
67442nut
Mar 22, 2015 10:16 AM
getitmann
May 25, 2012 08:40 PM
rtpassini
Nov 20, 2010 05:58 AM
Flye
May 12, 2009 05:30 PM
mcutlass1969
Jul 12, 2007 04:55 AM
