Center Link Rubbing Cross Member?
Old Apr 8, 2023 | 06:01 PM
Torquin's Avatar
Question Center Link Rubbing Cross Member?
My uncle has a 71 442, 455, that he has restored, and in the process has replaced the steering components. He tells me that when he turns to the lock the center link rubs against the cross member. He is not computer literate, so that's why I am here. Anyway, he tells me that he has compared this to another 442 that a friend has and while the friend's 442 has a 1/4" between the cross member and the center link, my uncles car only has about the thickness of a cardboard box material (his words). He mentioned a feeler gauge would be necessary to measure the gap. He has put two different new center links on the car, from different sources, and they both do the same thing. He does say that he sees evidence that it was wrecked. I do not know anything about the center link that came with the car when he bought it and I doubt anyone would have noticed an issue before restoration.
I am looking for ideas for a fix, or what else to check, and to find out if anyone else has encountered this situation.
Thanks,
Chris
Old Apr 8, 2023 | 06:52 PM
Funkwagon455's Avatar
I have seen this many times myself.
Old Apr 9, 2023 | 05:35 AM
Torquin's Avatar
Great, do you know of any solutions?
Thanks,
Chris
Old Apr 10, 2023 | 04:17 PM
I’m sorry, not particularly unless the suspension parts are simply worn, or perhaps out of alignment. Also try to remember the level of precision that these vehicles were built as well as the factory’s expectation of life. Maybe one of our local shaman can give a better explanation. I was merely expressing my personal experience.
Old Apr 10, 2023 | 05:42 PM
BackInTheGame's Avatar
You mention there is evidence of a wreck. I'm betting the frame is tweaked and not within spec. Try taking the frame measurements as shown in Section 2 of the Chassis Service Manual for your car. For example:
Old Apr 10, 2023 | 06:55 PM
classicmuscle442's Avatar
If there is a frame shop in your area I would have them check it out. Have a '70 that I couldn't get all of the bolts in the motor mount frame bracket, car had been hit on the passenger front.
Old Apr 10, 2023 | 07:36 PM
Sometimes, all you need to do is loosen the idler arm and the steering box bolts and move them a bit and retighten. It may give the necessary clearance. Without pictures it's hard to say, but all it has to do is clear.
Old Apr 14, 2023 | 06:17 PM
Torquin's Avatar
Thanks you all for the info and ideas. I am going to relay this to my uncle and see if he can get to the bottom of this.
Thanks,
Chris
Old Apr 16, 2023 | 05:06 AM
Post70's Avatar
Do the front tires wear? Is the camber correct? If the camber is negative the frame probably sagged between the frame rails. Repairable but not an easy fix with the engine and front clip to work around.
Dustin
Old Apr 16, 2023 | 09:57 AM
Torquin's Avatar
No info on tire wear. I don't believe he has driven it enough to wear the **** off the tires yet. He's been restoring this unit for years now, and is just getting to the driving part.
Thanks,
Chris
george landis
Wheels and Tires
Mar 29, 2023 08:57 AM
STLCRZY
Suspension & Handling
Feb 4, 2019 11:32 AM
TicTocTach
Aug 14, 2014 10:11 AM
archeryshooter
Feb 25, 2013 08:12 AM
1962oldsguy
Apr 6, 2012 08:36 PM
