WTB - Thermostat housing 1972
Old Apr 21, 2014 | 04:40 PM
442b's Avatar
L
Old Apr 21, 2014 | 05:15 PM
Originally Posted by 442b
Looking for a T-Stat housing for my 1972 Olds Cutlass 455. Needs to be either Stainless Steel or Polished Aluminum. Anyone know where I can purchase this? I've tried 2 chrome housing & all they do is leak, even filed them down flat as I could & they still leak. And yes, I've gooped them up real good with RTV silicone & still no luck. I've re-installed the original but would like to find one of the above. Thanks for any help.
I've never seen a stainless Olds t-stat housing. There are factory aluminum ones from the mid-1960s, but these require the J-shaped bypass hose as they do not have the metal goose neck.
Old Apr 21, 2014 | 05:30 PM
Gary M's Avatar
Is this it?
Mine looks like this. Bought from supercars unlimited. It leaked at J tube and main housing connection. They said send it back and they would replace it but I sealed it myself to save replacing the tower clamps. (see gray sealer in pic)
Old Apr 21, 2014 | 05:36 PM
Qwik71442's Avatar
Full-time Taxpayer
RobbMc, BTR, and Rocket Racing all have aluminum ones
Old Apr 23, 2014 | 08:19 AM
Arrowstorm's Avatar
Olds Wagonmaster
I got a good aluminum one with a stainless steel spout from Summit. Had to cut the spout a good half inch and bend it a little bit in my 80lb vice to get it to meet up with the water pump, but that certainly did the trick.
I also found that gooping it up with RTV sealant is not necessary and can be the actual cause of your leaks, especially with an aluminum housing going up against an aluminum intake. Not much actually sticks to aluminum... Sealing up the bolt threads is definitely necessary, however.
Old Apr 23, 2014 | 09:42 AM
Octania's Avatar
Another great place NOT to use RTV silicone. Especially not a lot of it.
Old Apr 23, 2014 | 02:25 PM
442b's Avatar
H
Old Apr 23, 2014 | 02:29 PM
442b's Avatar
Sorry but could you provide links, I typed what you gave into my browser and came up with motorcycle parts.
Old Apr 23, 2014 | 02:41 PM
70cutty's Avatar
Beer Connoisseur
http://www.robbmcperformance.com/pro...stat_olds.html
http://www.rocketracingperformance.c...ej2id52a23i5o6
Old Apr 23, 2014 | 07:03 PM
Arrowstorm's Avatar
Olds Wagonmaster
Man, i actually got it from their ebay store. I just searched for it and didn't find anything.
I know it won't help, but the auction # was 190959758641 from seller summitracing_sales
Came in a summit box, summit sales order and even some stickers.
Also included a picture and hopefully some of those numbers will help.
Ap6954
Mar 25, 2020 02:55 PM
Will22
Jan 30, 2020 07:44 AM
rpinnt
Feb 16, 2016 06:41 PM
69ishHoliday
Nov 9, 2014 04:33 PM
oldspower_68
Mar 23, 2012 02:18 PM
