wheels/intake
Old Nov 9, 2007 | 02:14 PM
ratsglass29
Guest
Posts: n/a
wheels/intake
Ok here we go again.....
1. Can someone give me the inside diameter of the 15 x 7 wheel. This would be on the backside just below the lip of the bead. Across where the disc brake caliper would sit down to where the wheel bolts to the rotor.
On the 14" wheel it's about 13 and 3/8"
2. Does anyone know the differance in hieght is between the stock intake and the Edelbrock torker intake is?
Thanks again in advance
Rick
Aftermarket
Main Entry: af·ter·mar·ket
Function:
noun
Pronunciation:
-"mär-k&t
1 :Does not fit
2 :
the market for parts and accessories used in the repair or enhancement of a product (as an automobile)
Old Nov 9, 2007 | 04:42 PM
If you're asking about the factory 15 x 7 SSII/SSIII rims, the inside measurement and disk brake clearance is the same for the 15" wheels and the 14" wheels. The problem is that both diameters use the same center stamping. The 15" wheels use a drop-center rim that has the same inner diameter as the rim on the 14" wheel. Unfortunately, this means the calipers have the same envelope to work in.
My442
Dec 26, 2017 05:08 PM
rhaberm
Wheels and Tires
Aug 31, 2012 05:34 PM
svnt442
Jul 17, 2011 04:43 PM
WTony
Jan 15, 2011 07:53 PM
71cuttyS
Oct 31, 2007 04:58 PM
