pictures of my 1966 442
Old Jun 28, 2009 | 09:34 PM
442 Guatemala's Avatar
Hello, after 2.5 years of restoration and many engine problems (I loose oil pressure and damage the engine) finally Im done with my 1966 442 400 engine. All matching numbers. here are some pictures.
I'm still having a little problem with my brakes, I installed a very high camshaft and i'm not having enough vacuum, so my booster is not working properly. actually I have a 8" dual diaphragm booster with a 1" corvette master cylinder, thanks for any advices to solve my brake problem.
hope you like the pics
Alex
Guatemala, Central America
Old Jun 28, 2009 | 10:03 PM
2blu442's Avatar
Nice looking car! It looks like your hard work paid off! Thank you for sharing the photos. John
Old Jun 29, 2009 | 05:53 AM
Ranzan's Avatar
Getting There
wow very nice car.......
Where in Guatemala are you? I`m picking a friend up this weekend from there
Old Jun 29, 2009 | 06:23 AM
wmachine's Avatar
Trying to remember member
Wow!! Looks great! Always good to hear about and see our Oldsmobiles from around the world.
Old Jun 29, 2009 | 06:30 AM
gearheads78's Avatar
car guy
beautiful car you have ...congrats on getting it done
Old Jun 29, 2009 | 07:23 AM
Oldsguy's Avatar
Past Administrator
Very nice looking, I really like the ghost flames on the hood and the interior color choice, that tan/fawn color is really, really nice with the blue. The engine bay looks cleaner than my wife's kitchen (don't tell her I said that).
Old Jun 29, 2009 | 08:11 AM
citcapp's Avatar
Alex,
Great looking car. I am also having problems with my brakes. I have the same booster and master cylinder in my 57 that you have in yours. Wondering if you bought yours on e-bay. No matter what I do I don't have enough brake and my cam in the 455 does allow for enough vaccum.
Old Jun 29, 2009 | 10:38 AM
Im in Guatemala City
Old Jun 29, 2009 | 10:41 AM
Originally Posted by citcapp
Alex,
I buy my booster and master cylinder on www.hotrodsusa.com I dont know what else I can do to fix my problem
Old Jun 29, 2009 | 01:28 PM
4fortwo's Avatar
With a 1" piston in the MC your brake issue is not likely a booster problem. From the pics I have two other possibilities.
1. The distribution block is sideways which will trap air and you won't get a complete bleed.
2. Your front brake line is running way too close to your headers and will damn near boil the fluid.
Old Jun 30, 2009 | 03:11 AM
Rdrokit's Avatar
I had the same brake problem on a 389 Pontiac engine with 3x2s and a big cam, low vacuum pressure so I ran an electric vacuum pump. There are a few brands out there but Comp Cams has a good one. here's their write up.
A high lift cam in a performance street vehicle can offer up great sound and excellent performance. But if your car or truck has power brakes, a minimum of 16 inches of vacuum is critical to proper brake booster operation, something not always present if your camshaft features enhanced overlap. The COMP Cams® Electric Vacuum Pump ensures that your vacuum stays between 18 and 22 inches so you never have to worry whether your brakes will be there when you need them.
Triggered by a vacuum switch included in the kit, the COMP Cams® Electric Vacuum Pump requires a 12V negative ground system and only operates when vacuum drops below 18psi and then turns off over 22psi. The kit includes all of the parts necessary to install the unit along with wiring, hoses and brackets. The system utilizes a highly efficient electric pump, relay switch and distributor with vacuum switch, which should be mounted close together for the most effective performance.
Old Jul 1, 2009 | 03:17 AM
German442's Avatar
@ 442 Guatemala:
Hi! Nice job! Ever think about getting a set of original rims & hubcaps for when you go to meets?
Ref your problem: See the quote AND:
I had just the opposite problem- rear brakes wouldn't release properly & locked up after 1/2 mile or so. Turns out when I converted the single master cyl to dual the cylinder didn't retract all the way. Had to get a guide machined to keep the brake actuating rod (manual brakes!) lined up w/ the piston, then adjusted the rod travel. Works fine! Just thinking your problem might be the piston isn't traveling as far as it should.
Might be worth checking it out!
Ralph
Old Jul 1, 2009 | 02:36 PM
Thanks for the advice, Im going to check that vacuum pump.
a Guy from hotrodsusa told me to remove the booster and just install a manual master cylinder, is that a good idea??
Old Jul 1, 2009 | 10:10 PM
Rdrokit's Avatar
In my opinion power brakes give you more stopping power in a heavy car than manual brakes. If you were driving a Ford escort i don't think it would matter but the Olds in a heavy car and would stop better with power brakes.
Old Jul 1, 2009 | 11:58 PM
German442's Avatar
REDROKIT is right- you need a really strong right foot if you need to stop a car that weighs around 3500lbs. The HotRod answer is OK if you're willing to live w/ that. I'm running manual brakes on mine, so I really leave a little more room between me & the car ahead! I can so that in Europe, as the German drivers are pretty disciplined. Not sure how drivers in Guatemala are, but I can imagine!!!
If you can, go w/ the electric vacuum.
Ralph
Old Jul 2, 2009 | 10:29 AM
I will try to keep that booster on, and see how to increase the vacuum.
yesterday I was cheking my car and I see a little of brake fluid leaking on the rear side of the master cylinder, im going to check what is causing that problem, any Ideas?
Old Jul 2, 2009 | 06:10 PM
4fortwo's Avatar
Bad piston O-Ring if it's leaking between the MC and the booster. If that's happening you found 90% of your problem.
Old Jul 3, 2009 | 10:05 AM
Thank you im going to check that and let you know
Alex
Old Jul 6, 2009 | 10:29 AM
RAMBOW's Avatar
Ben
Ralph
I don't agree with this. I actually prefer manual brakes to the overboosed power assist brakes. The problems you guys are having are the first reason, and the second reason is the big ugly booster in the engine bay. Looks much cleaner without it.
The master cylinder you use for Non-power brakes has a larger diameter m/c piston bore than the power brake master, so while it does have a little more pedal effort- it will still stop the car without a problem.
If you are into hardcore racing, those guys use hydroboost (use a booster that runs off your power steering lines) brakes.
Old Jul 6, 2009 | 10:40 AM
4fortwo's Avatar
The manual master cylinder has a SMALLER bore than a power brake cylinder. The smaller the bore the more concentrated the force from your pedal
Old Jul 6, 2009 | 05:35 PM
GoodOldsGuyDougie's Avatar
Money well spent. Have fun
montvaleplace
Feb 3, 2013 08:34 PM
dmontanagrizzlies
Jun 13, 2009 11:54 PM
jensenracing77
Feb 24, 2009 03:18 PM
deadbiker
Mar 23, 2008 03:20 PM
Oldsguy
Aug 31, 2007 07:49 AM
