Number crunching
Old Aug 2, 2007 | 07:42 PM
Jolly Green's Avatar
Number crunching
Hey guys. Finally got the 68 442 home and got some numbers off it. Maybe you guys can help me decipher some of the deeper meanings.
396021 F
Vin unreadable mostly, grabbed the last 3 digits "935". Obviously not numbers matching.
Oil Filler Tube
1141665
Heads
G 6 (Driver side)
G 4 (Pass Side)
CFD 409 100 212
Edelbrock Carb
Only number could find on passenger side front flange
4407 2421
Edelbrock Intake
Performance Olds 445
Talk to me brothers! It looks to me that the heads are off a 1971 Olds 455. The engine appears to be cast from 1968-1972. So am I to assume they came together? A 71 455?
I can't identify the carb, I could really use some help on that. Want to know what I'm working with. I think the intake is a Performer RPM version.
And anyone out there with a 68 442, did you find your build sheet somewhere? And where was it? My car is from Fremont, CA.
Oh, and does anyone sell the rear cowl thing on the hood?
And does anyone here run a Hurst shifter for their automatic and can convince me to as well?
Thanks guys!
Old Aug 3, 2007 | 04:41 AM
Jim's rare 80's Avatar
Jim's rare 80
Hi. Here goes.
396021 "F" code from beside oil filler tude says 68-72 455.
Head codes are between exhaust manifold, and valve cover, three didgets either side of center bolt. Six didgets in all. Let us know.
Also, if the "935" matches a "935 in the last vin #'s to the car, It MAY be #'s Match. let us know what you find out.
Jim.
Old Aug 3, 2007 | 06:31 AM
Sadly, the last three in the VIN are WAY off from the engine VIN. But the Heads and block seem to line up together.
Alg
Jan 1, 2013 05:04 PM
Chumley
Jan 19, 2009 09:02 PM
olds53rocket
Dec 22, 2006 05:46 PM
1BAD68"S"
Sep 17, 2006 06:49 AM
dcarson
Aug 22, 2006 11:00 AM
