New tires for my 69 442 convertible
![Cool](https://classicoldsmobile.com/forums/images/icons/icon6.gif)
Can anyone tell me if red line tires are correct for a 69 442? I have BF Goodrich Radial T/A on it now but they need to be replaced and I thought red lines would look good.
And one more question...Was it an option in 69 to have rally wheels painted the same color as the body of the car? Mine are and it looks great but I am in the process of upgrading my paint so now is the time to restore to what is correct.
Red stripe was an option!
Oldsmobile wheel terminology (super stock) not rally. SSII's were argent grey.
To glean some info on your own, join wildaboutcars.com.
Also here is a link to Oldsmobile wheels.
http://www.oldsmobility.com/old/superstock.htm
Pat
Pat
I thought all 4-4-2 models came standard with red stripe tires in '68 and '69. Of course, other tires could be ordered in place of the red lines if you didn't want red lines.
SSII wheels in '68 and '69 were 14X6. The 14X7 wheels started with model year 1970.
Randy C.
Randy C.
Now correct me if I'm wrong. I thought Olds used dark argent grey. Close to a charcoal color. The pic above looks like argent silver used on Chevy wheels. I'm too young to remember them new (born in 1977). And everybody seems to have them painted body color nowadays.
My wheels on my 70 are silver. I was told they were not correct but it matches my color scheme.
Red Lines
Red Lines were optional not standard. I have owned numerous 1969 442s & have build sheets for 2 of them & the original purchase order for a third. None of them came with Red Lines.
In 68, the 442 came with a F70 14" 2 ply wide tread Red- line Nylon cord tire as standard equipment.
According to the specs the white line, nylon cord tires(7.75 x 14") were avail only with the 455 and power front disc brakes and were available at no charge
A radial whitewall was even available,205R14 but was only available on the L65 Turnpike option.
Not sure of 69.....
Ted
Not sure of 69.....
Ted
My 69 442 conv was optioned with red lines and SS1 wheels. I have been wanting to go back to that from white letters also since would look great , especially since the car is sliver with black interior and top. However, the redline radials are twice as expensive as BFG Radial T/A's
Anybody know where to get them at any discount ?
![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
Not sure of 69.....
Ted
Not sure of 69.....
Ted
Anyone who thinks otherwise is welcome to pony up some proof.
And that's not to say you could have gotten a different tire. For instance, my '68 4-4-2 came with white line nylon cord tires. But those tires were specifically requested and that's why the car came that way. If a certain tire had not been specifically requested for the '68 or 69 4-4-2 models, the car would have come with red stripe tires.
Thanks, Kurt!
Randy C.
Thanks, Kurt!
Randy C.
more
In my earlier post I wrote none of them came with Redlines. What I meant to type was none came with redlines "as standard equipment" as the redlines are listed as an added option.
I just looked at my GM of Canada documentation for the Pewter 1969 442 that I sold a year ago. It shows the car as built & lists all the options on the car. As one of the options on the car Option code N81 and described as F70 x 14 red stripe tires on 14 x 6" JK wheels.
So if this is a standard item on all 1969 442s why is it shown as an option on this car?. By comparison U80 is another option on that car (rear seat speaker). Certainly that was not standard on all 442s was it?
Just to add..
......and my 68 442 lists it's tire as an option also...
PW8. F70 14 4 PR-RED STRIPE
I cannot find any imfo on RPO code PW8![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
The car is Oshawa built.....
As Dave points out, why is it listing a tire as an option when it is listed as standard equipment?
Ted
Ted
There may be some confusion here with what an "option" is being called. Some RPOs are an option, but are standard equipment in some circumstance. And in some cases an RPO is a "required option". So the devil is in the details, and sometimes the terminology is totally misleading. From a logical standpoint, how can an "option" be "standard" or "required"?
Truth is that "RPO" is misleading to begin with. Maybe should have been called a "feature" instead of an "option".
more info
My Oshawa built Turquois 1969 442 was built on Aug 27th & was the 124th car built @ Oshawa. A day later on Aug 28th they built my Pewter car which was the 340th car built. The Turquois car build sheet makes no mention of red line tires as an option while the Pewter car has them as an option on its' build sheet.
So...me thinks that the rules @ Oshawa were different from those at the USA assembly plants.
It still amazes me that these two cars built 1 day apart in August 1968 ended up sharing a garage 44 years later. Especially when the Pewter car was built for the Halifax NS sales zone but went unwanted & eventually sold to a dealer in Vancouver B.C. while the Turquois car was sold in the center of Canada in south central Saskatchewan. Apart from body color & power windows on the Pewter car they were near twins.
![](http://i37.photobucket.com/albums/e81/oldsmobiledave/Bothersreunited002.jpg)
more
I have sold both of these cars (I kept the gold 69 442). The Turquois car is now in Vancouver with a member on here & the Pewter car is in the hands of a friend in my home town.
I will try to post copies of the GM of Canada documents later.
Keep in mind that the data used to make the Canadian docs just basically list the VIN and RPOs. George fills in the descriptions of the RPOs on those docs.
If the GM Canada docs are the source of your information for standard vs optional, then I can tell you for sure that it can be misleading. As mentioned above, the raw data for the docs you get is a listing of VIN and RPOs for that VIN. Though almost all of the RPOs are truly options, they can include options that are standard equipment *for that particular car* and "mandatory options". Take a look at this 1970 build sheet. There are about 30 RPOs shown. But more than half of them are standard equipment for this car, as noted by the "*". The L31 is not shown as an "option" because it is standard in the 442.
But that may or may not be shown in the Canadian docs because it is is an RPO that shows up on the build sheet.
This tire situation is further complicated in 1969 with having 2 factory redlines, the old N81 wide ovals and the new P81 fiberglass belted. At a time when the white letter tires were just taking off and not many wanted the old style redlines. Of either type!
As for the Argent Silver color question there are many shades of that color. I have read here (somewhere) that they sprayed those wheels and the top of the barrel of paint was lighter than the bottom and of course the paint most likely varied depending on batch. I have 5 sets of SuperStock rims and at least three looked original (no extra coat of paint) and all three were a different shade - most were on the darker side. I erred on the darker side as well.
Ted
* N81 TIRE F70X14RS
and also
F70X14 RED 2/4 PLY OE
in the box
so I would have had the Wide Ovals.
and mine does have the "*" just as my W29 442, M14 3 spd does as that is what came with the model, while my console and SS1's does not. Learned something new.
oldsguybry
Wheels and Tires
19
February 16th, 2013 09:14 PM
Jeff70442
March 31st, 2012 02:39 AM
