Need to find a Fuel Sending Unit for my 67 442
Hey everyone, I need your help. I've been searching around and I can't seem to find the proper replacement for my fuel sending unit. Most places I look don't have a unit for the 67. Maybe I'm not looking in the right places.
Can anyone point me to a site they trust and shows the fuel sending unit in stock w/ all hardware and filter?
Reason I need it is my fuel gauge doesn't seem to be getting a proper signal from the unit. I've tried to ground it better per suggestions on other threads, and it didn't seem to work. My gauge shows full all the time.
Thanks for your time and help.
http://www.autocityclassic.com/index...=930&Itemid=64
These Chevy ones look the same to me. Other than the filler neck the tanks do too.
Does this look like the proper unit. Found it in another post when I tried a different search. http://www.autozone.com/autozone/par...ntifier=210442
hey several places to get them if it is a true 442 the tank has 2 lines one is a return line. i got mine from a parts place called original parts group (www.opgi.com) they have an online catalog for the cutlass/442. also u can go to yearone...hope this helps...gary
Regardless of the condition of the sending unit and whether it's even hooked up or not, you should be able to force the gauge to read Empty by simply grounding the wire coming from the gauge to the sending unit with the ignition in the ON position. This would at least verify that your gauge is working correctly. There is usually a place in the wire in the rear license plate area where the wire from the sending unit connects to the wire from the gauge through a pull-apart connector. Pull this apart and ground the gauge side.
Until you verify that the gauge is working properly, you don't know that it isn't the problem, and wouldn't you hate to go through the trouble of buying and replacing the sending unit only to have your gauge still not work? I think I would.
68RocketAction
December 18th, 2014 11:19 AM
Oldskool84
October 10th, 2014 06:21 AM
