Looking up block and vehicle numbers
Old January 16th, 2012, 11:12 AM
JBishop's Avatar
Trying to locate and see if the numbers match on a 68 olds 442 that I have.
JBishop is offline
Old January 16th, 2012, 01:02 PM
Lansing built
1970cs's Avatar
numbers
Throw us your numbers! between most of the people here on the forum you will get your info.
1970cs is offline
Old January 16th, 2012, 01:11 PM
Trying to remember member
wmachine's Avatar
Number crunching galore!
http://wildaboutcarsonline.com/cgi-b...aldisplayed=26
http://wildaboutcarsonline.com/cgi-b...=9970399476565
Wild About Cars. http://wildaboutcars.com. An information supersource, especially Oldsmobile. More Olds content than anywhere else on the internet and continuing to grow.
You'll find Chassis Service Manuals, Product Information Manuals (AKA Assembly Manuals), Inspector's Manuals, and other documents that will contain this and much much more.
Dealer Brochures, magazine ads and articles, and a home page for you online with your own garage where you can show off what you have.
Free to join, free to learn.
wmachine is offline
Old January 17th, 2012, 08:33 AM
JBishop's Avatar
This is the body numgbers.
68-33687 LAN199679
TR-940 N-N paint
Where are the block numbers?
JBishop is offline
Old January 17th, 2012, 09:13 AM
wmachine's Avatar
68-33687 LAN199679
TR-940 N-N paint
With all due respect, the answer is in the third link I just gave you.
wmachine is offline
Old January 17th, 2012, 09:26 AM
allyolds68's Avatar
In all fairness to the guy I can't find where it shows the block pad for the Engine VIN # Stamp in your link above which is what I would look for when trying to figure out if it was a "matching numbers" engine. I know you can find it in the service manual and assembly manual but that definitly takes some work to find it
JBishop,
There's a small machined pad on the black under the #1 cylinder head that may be obscurred by the power steering pump. The last 5 or 6 (I can't remember off the top of my head) numbers should match the last 5 or 6 of your VIN. First you should check what WMachines had posted above to find out if you even have the correct engine. You can't tell much of anything about "matching numbers" from your cowl tag. You can't even tell it's a 442 from a 68 Lansing cowl tag. The best you can do is look at the build date of your car body (which is about the only thing you didn't post from your cowl tag) and then look to see when the rest of the componants (block, heads, etc) were produced.
BTW there are about a million posts asking the same question. The search function works pretty well here.
allyolds68 is offline
Old January 17th, 2012, 11:34 AM
JBishop's Avatar
The vin# is 344878(M or W)I can't read it, then194441.
block number is 396026G
JBishop is offline
Old January 17th, 2012, 01:30 PM
svnt442's Avatar
That's the casting number. You need to find the number stamped into the block below #1 spark plug. If it's the original block it will read 38 (M or W) 194441
svnt442 is offline
Old January 17th, 2012, 08:28 PM
rsandhoff's Avatar
I have added a pic showing where to look for the number they are telling you about. The head is off on this pic, but you can read with the head on also. As mentioned, it is below the #1 cyl.
rsandhoff is offline
tinascars
May 17th, 2016 07:55 PM
Dbechtel71
October 23rd, 2013 06:49 AM
Jannebill
June 27th, 2011 08:51 PM
Moses
February 23rd, 2011 05:58 AM
wylie
October 2nd, 2006 07:50 PM
Quick Reply: Looking up block and vehicle numbers
