Let's talk rear ends
Rear differential and axles that is. I am attempting to sort out the various rear diffs used in the 442 over the years. What I have deduced so far:
1964 442--Pontiac/(Buick?)-sourced 8 1/8" ring, 10-bolt cover (notched at 3-o'clock and 9-0'clock)
1965 442--Pontiac/Buick-sourced 8 1/8" ring, 10-bolt cover (notched at 3-o'clock and 9-0'clock)
1966 442 and W30--Pontiac/Buick-sourced 8 1/8" ring, 10-bolt cover (notched at 3-o'clock and 9-0'clock); Olds-sourced 8 1/2" ring, 12-bolt cover (late)
1967 442 and W30--Pontiac/Buick-sourced 8 1/8" ring, 10-bolt cover (notched at 3-o'clock and 9-0'clock); Olds-sourced 8 1/2" ring, 12-bolt cover
1968 442--Olds-sourced 8 1/2" ring, 12-bolt cover; 442, W30, H/O-- H.D. Olds, 12-bolt cover (no notches); Chevy Canada (McKinnon)-sourced, 8 7/8" ring, 12-bolt cover, with Oshawa-built units only - no W Machines or H/Os
1969 442--Olds-sourced 8 1/2" ring, 12-bolt cover; 442, W30, H/O-- H.D. Olds, 12-bolt cover (no notches); Chevy Canada (McKinnon)-sourced, 8 7/8" ring, 12-bolt cover, with Oshawa-built units only - no W machines or H/Os
1970 442, W30--Olds-sourced 8 1/2" ring, 12-bolt cover; 442, W30 w/W27 12-bolt cast Al cover w/ Al center section
1971 442, W30--Olds-sourced 8 1/2" ring, 10-bolt stamped steel cover or 10-bolt cast Al cover (with W27 only)
1972 442, W30, H/O--Olds-sourced 8 1/2" ring, 10-bolt cover
1973 442, H/O--Olds-sourced 8 1/2"ring, 10-bolt cover; Buick-sourced 8 1/2" ring, 10-bolt cover; Chevy-sourced 8 1/2" ring, 10-bolt cover
1974 442, H/O--Olds-sourced 8 1/2" ring, 10-bolt cover; Buick-sourced 8 1/2" ring, 10-bolt cover; Chevy-sourced 8 1/2" ring, 10-bolt cover
1975 442, H/O--Olds-sourced 8 1/2" ring, 10-bolt cover; Buick-sourced 8 1/2" ring, 10-bolt cover; Chevy-sourced 8 1/2" ring, 10-bolt cover
1976 442--Olds-sourced 8 1/2" ring, 10-bolt cover; Buick-sourced 8 1/2" ring, 10-bolt cover; Chevy-sourced 8 1/2" ring, 10-bolt cover
1977 442--Olds-sourced 8 1/2" ring, 10-bolt cover; Buick-sourced 8 1/2" ring, 10-bolt cover; Chevy-sourced 8 1/2" ring, 10-bolt cover
1978 442-- Chevy-sourced 7 1/2" ring, 10-bolt cover
1979 442, H/O-- Chevy-sourced 7 1/2" ring, 10-bolt cover
1980 442-- Chevy-sourced 7 1/2" ring, 10-bolt cover
1983 H/O-- Chevy-sourced 7 1/2" ring, 10-bolt cover
1984 H/O-- Chevy-sourced 8 1/2" ring, 10-bolt cover
1985 442-- Chevy-sourced 8 1/2" ring, 10-bolt cover
1986 442-- Chevy-sourced 8 1/2" ring, 10-bolt cover
1987 442-- Chevy-sourced 8 1/2" ring, 10-bolt cover
If any of you can supply pics of the various rear ends and their covers, that would help greatly.
Please correct me if I am wrong in any of the above entries.
I could be wrong but I always thought the BOP rears (10 or 12 bolt cover) had an 8.2" ring gear until '71 when they went to the "Corporate" 10-bolt that had the 8.5" ring gear. Also I think only the '83 H/O had the 7.5' gear then in '84 they went to the 8.5". I'm sorry if I'm WAY off with all this. It's just what I've been told.
Thanks, Mike. I made changes to the chart. Checked my '87 Buick manual and found the turbo V6 did use the 8.5 rear. I know that the Olds 442 and Buick GN both used the same rears in the late '80s. I also ukpdated the Pontiac rears to the 8.125" ring gear.
Yes, in fact it is exactly the same housing, by part number, as the one used in 1968, despite the 1.5" difference in track width normally between the 64-67 cars and the 68-72 cars.
Good thread.
After all these years I still have a time getting rear ends straight.
I had a '67 Cutlass 3-speed floor shift car that had a 12-bolt (cover)
10 bolt rear with a 3.08 gear.
Oldsmobility.com has a really good section on Olds rear ends:
http://www.oldsmobility.com/old/reardiffs.htm
http://www.oldsmobility.com/old/10bolt-tech.htm
The Olds Service Guild Bulletin (May 66 iirc) documented that some late 66s had the Type O. High numerical ratios weren't available until later, so the Type P continued in 66-7 for performance ratios like 3.91, 4.11, etc.
Thanks guys, I've updated the listing.
I've also added Buick-sourced axle ***'ys to the mix for at least '65-'67. Can anyone confirm the use of Buick rears for '64?
Still looking for pics for all O, C and K type rears.
Just to be clear, "Type O" refers to the axles used on late 1966 through 1970 cars that have the 12 bolt cover but 10 bolt ring gear. A 1972 Cutlass has a" corporate" 10 bolt axle, but it does have the Olds-unique bolt-in axles. Differential and gears do interchange with other 10 bolt axles.
Lady72nRob71
February 17th, 2011 01:17 PM
J-(Chicago)
Drivetrain/Differentials
December 11th, 2007 07:08 PM
