I'm mixed up, which is my original fan blade???
Old Jan 21, 2011 | 11:48 AM
ROCKET VAPOR's Avatar
Lance
I have two fan blades, but I can not figure out which one is my original and which one was given to me years ago?
One fan has the outer edge of each blade squared off, and the other fan has the outer edge of the blade rounded off.
Both fans are 19.5" in diameter.
Both fans have the word "front" stamped and a circle with a "5" in the middle stamped on the fan assembly's center section.
No part numbers stamped on the front or back side of either fan assemblies.
Is one a Chevy and the other an Oldsmobile fan blade?
BTW, the car in question is a '70 442 w/ A/C & HD cooling.
Front side
and.... the back side
Old Jan 21, 2011 | 11:57 AM
Mike H.'s Avatar
I say the black fan is the correct one. It looks like my Pontiac fan with the rounded edge
Old Jan 21, 2011 | 04:04 PM
BlackGold's Avatar
I'm not staring at my car right now, but I'm 99% sure that its fan, which I believe to be original, looks like the black one you have pictured. My car is a '70 442 with A/C.
Old Jan 21, 2011 | 06:10 PM
MHENDERSON's Avatar
Im going with the black one.
Old Jan 21, 2011 | 07:21 PM
rcorrigan5's Avatar
Randy C.
The clutch fans on my '68 4-4-2 with HD cooling and '69 4-4-2 with A/C both appear identical to your black fan.
Randy C.
Old Jan 24, 2011 | 06:11 AM
Lance
Black one it is then, thanks guys!!!
Old Jan 24, 2011 | 10:28 AM
Run to Rund's Avatar
Make sure it clears the shroud if you have one. 19.5" is pretty big; Iirc the 66s used no bigger than 19" for example.
Old Jan 30, 2011 | 09:44 AM
bobb's Avatar
Yo Rocket.....it's the black one. Not sure what the other fan is off of. Big block Chevys almost always used a 7 blade fan with the curved edge. So the straight edge fan is a mystery.
regards,
bob
Old Feb 8, 2011 | 05:25 PM
BlackGold's Avatar
The answer to the question "Which of the two fans pictured is correct for a 1970 442?" is NEITHER.
See my post of 7-Feb-2011 at: https://classicoldsmobile.com/forums...fan-blade.html
toymobile
Jun 9, 2015 03:41 AM
dnmfranco
Sep 14, 2014 04:54 PM
MJAKS462
Apr 1, 2010 05:04 AM
68Tom
Apr 3, 2009 04:41 PM
DennisG.
May 23, 2008 11:43 AM
