Exhaust for 68' with W/X manifolds?
Old Nov 20, 2017 | 05:55 AM
Brad J.'s Avatar
I've searched around the forum but couldn't find the information I was looking for. Just recieved new exhaust manifolds with a W/X on them. They are from Fusick/Thornton. For a 68' 442 what year exhaust should I order for with these manifolds? Our car had a 350 w/ crossover manifolds when we got it so I don't know what style the originals were. Now it has a 455 and I want to order the correct style exhaust for the car and I don't know if these manifolds are like the originals.
Old Nov 20, 2017 | 06:59 AM
Those are the 389268 and 389269 castings used for 1965-67. The correct RH manifold for 1968 would be the 389706 "Y" casting. The LH 389269 "X" was used in 1968 also.
Functionally, the only difference between 389268 and 389706 are the ribs for the hot air stove on the outside of the manifold. The exhaust outlet is in the same place on both relative to the ports, so correct 1968 pipes should bolt right up.
Old Nov 20, 2017 | 07:56 AM
Brad J.'s Avatar
Thanks Joe,
My dad ordered these for a 68' but who knows. Thanks for the extra information, these will work fine for our application. I'am going to lop the heat riser flap out and braze the end of the shaft in place so it looks operational. It's a substantial size shaft running through the center of the outlet.
Old Nov 20, 2017 | 09:58 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Also, consider plugging the exhaust crossover passage in the intake. You will need to convert the choke to electric.
Old Nov 20, 2017 | 10:17 AM
Brad J.'s Avatar
We did that when we rebuilt it and the Q-jet he bought from Jet has the electric choke. Thanks, Brad
Here it is right before break in and before I cobbled the exhaust, dropped in a distributor and such.
Old Nov 20, 2017 | 01:27 PM
RetroRanger's Avatar
72 Olds CS
my 72 had a 350 w stock manifolds and the exhaust pipe crossover blocked off so it had dual exhaust.
I swapped in a 455 w W & X manifolds eliminated the heat riser flap and converted the Q jet to e choke. The dual exhaust from the 350 bolted right up to the 455 manifold after i loosened and adjusted the pipes slightly
Jun 3, 2019 11:53 AM
bulky
Aug 28, 2006 11:59 AM
linas9
Feb 23, 2006 01:10 PM
EdsDelta
Jul 22, 2004 11:46 AM
copper128
Mar 21, 2004 09:43 PM
