engine size
i am asking how can i differ a buick 350 engine from a buick 455 one?
i cant reach the engine id on the block due to dust on it. The engine is in a 1976 olds 442 and i can't recognize it if it is a 350 or a 455.
Thanks for your help
Note on the Buick engines the distributor is on the front of the engine and fuel pump is on the left. I'm not sure if the Buick is the same as Olds as far as the difference between the SB and BB is basically deck height.
Buick 350
Buick 455
Olds 350
Olds 455
Buick 350
Buick 455
Olds 350
Olds 455
the distributor is on the front of the engine and fuel pump is on the left.*It is a buick. the previous owner may had replaced the original engine. But i cant post pictures of my engine due to an error i dont know what it is. if you send me your email i will send them to you. I am from the Middle East, Lebanon.
I've had some researches and noticed that my engine is a buick. Maybe the previous owner replaced the original engine with a buick. The distributor is in the front and the fuel pump on the left of the engine so i am sure it is a buick.
The engine color could help me to know it's size? If yes how? And where can i find the id no. of the engine? And the size of the block (350 or 455)?
I really thank you guys for your help
As Eric said, Buick engines had a cast number corresponding to the displacement on the rear shelf, just forward of the transmission.
Since I'm an Oldsmobile guy, I didn't know that. I had to Google it.
If you don't find your answer here on CO, try this http://www.v8buick.com
Wildcard
December 9th, 2012 10:35 AM
