Coil Spring Replacement
Old Sep 11, 2016 | 02:49 PM
servexcell's Avatar
i am restoring my 68 cutlass convert. i am installing a dribetrain from a 68 442
Starting to reassemble the front end , what coil springs should i use for the front and back to keep the stock ride height.
Bruce
Old Sep 11, 2016 | 04:31 PM
Anything wrong with the ride height that it currently has. If not then just cleanup and use your old springs.
Old Sep 11, 2016 | 07:38 PM
servexcell's Avatar
i believe it was OK. Car has been apart for approx 1 year so far . I thought installing the 400 it might need springs from a 442
Bruce
Old Sep 11, 2016 | 07:48 PM
Ok, misunderstood, there is about a 60# difference in the weight of an sbo vs bbo. If your changing manifolds to aluminum and adding headers that weight difference decreases.
Harmon
Dec 14, 2014 06:26 AM
BStone
Jul 31, 2012 06:17 PM
O's_Car
Suspension & Handling
Apr 11, 2011 04:24 PM
Longhorncutlass
Mar 2, 2009 01:53 PM
