Aftermarket throttle body fuel injection
Old December 18th, 2015, 12:25 AM
kansjfr's Avatar
Have any of you retro-fitted your 442 with the aftermarket throttle body fuel injection available from MSD, Edelbrock, etc.? They're pretty pricey (over 2k), but they advertise that they eliminate alot of fuel related performance hiccups that carburetors have. Any input would be helpful.
kansjfr is offline
Old December 18th, 2015, 09:25 AM
RROLDSX's Avatar
Wink
Carburetors Man, that's what life's about!
Anyone remember which movie that was in?
RROLDSX is offline
Old December 21st, 2015, 07:51 AM
RROLDSX's Avatar
It was Phantom of the Paradise in case anyone wants to know. Back to the OP, my opinion is unless you drive mega miles it is a waste of money. If your having stumbling and performance issues, there is something wrong and should be fixed. If it is the carburetor that is causing your grief it is a relatively cheap fix. The source of your problem should be resolved before you even think about FI. JMO.
RROLDSX is offline
Old December 24th, 2015, 07:49 AM
HWYSTR455's Avatar
I did a write up of an install of a Holley Terminator on the 442 clone, haven't had the time to also post here, but this is the link:
http://forums.maxperformanceinc.com/...ght=terminator
FiTech has a self-learning system that is under $1k, and they are staging for a price reduction:
http://www.fitechefi.com/default.asp.pg-Products
There's a fairly informative thread on PY regarding this system, and many have installed it:
The benefits of an EFI system are obvious, but just to say, TB setups are generally better for engines under 600hp, personally I say more like in the 350-500hp range. Multi-port is your best choice for over 500hp, and/or if you have a forced induction engine.
When I was on the 2014 Power Tour, going over the Cumberland mountains, 3500 ft, my carb engine leaned out by 4 jet sizes, at least, and had to do a roadside adjustment. Once I came out of the clouds, I had to jet back down. That made the decision for me regarding EFI.
The number of people that were side-lined for that segment were many, and at times saw groups of people pulled over. I like to drive my cars, so it was an easy choice for me.
The clone is a 355 with iron heads, with the carb in not so perfect conditions, ran low 13s. With the throttle body, just by seat of the pants, I can easily tell it's quicker and more linear power, though haven't had it to the track yet. Throttle response, mpg, and drivability have all improved a noticeable amount.
I will never go back to carbs.
HWYSTR455 is offline
archeryshooter
February 9th, 2014 09:19 AM
cheven
December 5th, 2011 06:57 AM
cwracer
November 20th, 2011 03:55 PM
bud442
November 19th, 2009 10:31 AM
BlueBlock350
April 9th, 2008 10:38 AM
Quick Reply: Aftermarket throttle body fuel injection
