!970 Cowl Tag Help
Old Apr 21, 2009 | 05:26 AM
harry442's Avatar
!970 Cowl Tag Help
I am looking at a 1970 442 and I can't figure out this cowl Tag:
70-34467 E 569 BODY
977 WA 4035 A PAINT
01B A31
Old Apr 23, 2009 | 06:46 AM
alw's Avatar
alw
There ae much more knowledgeable people than myself on this site, but this is my guess;
170 442 Convertible / built in Linden NJ / unit # 569
Ivory bucket seats / Nugget Gold Paint / White Top
Built 2nd week in Jan / A31 could be power windows?
Old Apr 23, 2009 | 06:59 AM
Originally Posted by alw
...A31 could be power windows?
Yup. The Wiki is your friend:
http://www.oldsmobilewiki.com/index....y:Option_Codes
Old Apr 23, 2009 | 05:57 PM
442's Avatar
70' W-30 Convertible
I thought all 1970 442s were built in Lansing? Or is that just W30s?
Old Apr 23, 2009 | 07:57 PM
W-cars were only built in Lansing. 442s were built at all Cutlass assembly plants.
Old Apr 25, 2009 | 05:49 AM
442's Avatar
My mistake, thanks.
Old Apr 25, 2009 | 10:46 AM
ctrain22's Avatar
Where can i go to get trim plate decoding info? I want to find the codes for a 68 I am purchasing. Looking for paint and trim codes.
Old Apr 25, 2009 | 11:30 AM
344870M's Avatar
http://www.yearone.com/updatedsingle..._body_tags.htm
This should get you started.
Old Apr 25, 2009 | 12:03 PM
ctrain22's Avatar
Thanks for the info. Now I need to find what my specific codes are. Maybe some one can confirm what I have. 68 442 convertible.
06C
68-33667 LAN427848
Tr 947 Y-1 Paint
Old Apr 25, 2009 | 12:36 PM
344870M's Avatar
1968 - (3)Oldsmobile (36)Deluxe F85 (67) convertible (LAN) sing MI (427848)Car serial number
(TR)im (947)Pearl vinyl buckets (Y-1) not being a "68" guy I can't decode this.
Unfortunately everything I have at my disposal tells me that the (36) code should be (44) if it were indeed a 442. But don't despair until a true "68" expert chimes in. But don't get your hopes up either. I'm pretty sure about this code.
Old Apr 25, 2009 | 02:32 PM
ctrain22's Avatar
It is a 44 in the serial number. 344678M423892. Just the trim tag shows different, which I understand is common because the trim plate is more fisher body coding. But, that's why I am questioning here. Also, from a website 442bro.com, it seems the Y-1 is Safron yellow with back top, but this car is Yellow with white top. Although, the top might have been replaced at one time to white. Again, that's why I am here.
Old Apr 25, 2009 | 03:21 PM
ctrain22's Avatar
Interesting, I just found this on 442.com.
1968:
Authentication:
  • No 455's, only 400's.
  • The body data plate will not match the VIN. All 1968 442s have 344878... VINs, but the body data plates for those years will carry a 3687... designation. This is well documented and nothing to worry about. Similarly, the sequence number on the body data plate will not match the last six digits of the VIN (except in the event of an extreme coincidence), since these were Fisher Body numbers, not VINs. To sum up, while the body data plates on the 68-69 cars carried Cutlass body numbers, the VIN for a 68 442 must start out 344878.
  • Air cleaner housing: The correct color for all 4bbl 442's (non W-machines) is an Orange/Red. W cars had a black base and a chrome lid, and 2bbl 400 442's had a black air cleaner that was identical to the one used on 2bbl small block cars.
  • My 68 442 Conv has no model markings on the door panels, only on the glovebox door. Perforated diamond pattern on top of panels and flat from the armrests down, no carpet.
Made a subseries in itself, new body shape using GM's 112 inch wheelbase, a black mesh grid pattern grille (A Cutlass S should have a grille with vertical bars) with 442 identification. Production of the 442 for the 1968 model year was a record. 442s did not use an "Oldsmobile" script on the grille. Non-44s used a chrome OLDSMOBILE script on the left front corner of the hood on non-442s. 442s deleted the Olds script on the hood and used large 442 numerals on the grille. 442s will have a black plastic egg-crate grille, while non-442s will have a silver plastic grille with vertical bars.
Old Apr 25, 2009 | 03:25 PM
344870M's Avatar
I'm glad you found that out. I wasn't going to touch your question anymore because based on what I know about '70 442's, your numbers just didn't make sense to me. So I thought it best to leave well enough alone. Next time ask a question about the 1970 442.
I'm glad you've got 442 though and not an "oops!".
Old Apr 25, 2009 | 04:57 PM
ctrain22's Avatar
With the trim being 947, is it white, pearl or parchment? What color would I order to redo hte buckets?
SwiftyOlds
Oct 26, 2012 08:51 AM
L69
Sep 30, 2012 05:03 PM
m455sx
Jun 26, 2011 05:55 PM
bil
Dec 16, 2010 08:22 AM
harry442
Oct 18, 2008 03:20 PM
