69 442 cowl tag
Old Aug 20, 2008 | 08:46 AM
VikingBlue's Avatar
69 442 cowl tag
I've read on another site that the 1969 442 cowl tags stated the Cutlass body code (33687) rather than the 442 code (34487) at least through March of the 1969 production.
Was this for all 442s ? For some ? Only in Lansing ?
Given the above assumption, and with not seeing a lot of 442s around to compare, it struck me as odd that one that I saw recently with an early build date had the correct 34487 code on the cowl tag.
Old Aug 20, 2008 | 12:51 PM
Many (possibly most) but not all 68-69 442s got 36xx body tags. The difference may be assembly plant related, but I've never seen data to prove or disprove that.
Old Aug 20, 2008 | 05:20 PM
kevdog442's Avatar
Member
curious
I've always wondered that if thats true then why does every Cutlass Supreme I've seen (68-69 which have the same body as a 442) have a 342 body tag and others (F- 85,etc.) seem to always have the correct body tag. It just seems a little fishy to me, especially when I know how simple it is to change a vin tag. My 69 442 has the correct 344 body tag.
Old Aug 20, 2008 | 05:45 PM
I don't know about "fishy", but it is completely documented in the Fisher (sorry) Body Manual for the 1968 and 1969 model years. I've always suspected that this is a throwback to the 67-earlier cars where the 442 was an option package. Note that the Supremes for those years had different upholstery and trim, so that as far as Fisher Body was concerned, they were different and thus got a different body code. The 442s, on the other hand, got the same upholstery and trim as the Cutlass, hence the same body code as far as Fisher Body was concerned.
Old Aug 20, 2008 | 07:05 PM
VikingBlue's Avatar
Kev - is yours a Flint car ?
The car I saw with the correct 344 tag was a Linden, NJ car.
Old Aug 20, 2008 | 07:12 PM
kevdog442's Avatar
Member
Makes sense
I guess I wasn't thinking about the upholstery and trim, only the body. So that makes sense. Mine was made in Fremont, Ca. and here in the midwest I see a lot of Cutlass tags on 442s so it could have been a Lansing thing.
Old Aug 21, 2008 | 10:10 AM
Cutlii of this vintage were not built in Flint.
duckblaster67
Nov 24, 2020 03:01 PM
bummerino
Mar 30, 2010 04:45 PM
66cv442
Aug 20, 2009 07:52 AM
captn442
Mar 15, 2009 07:26 AM
compusign1967
Oct 30, 2007 08:19 AM
