68' 442 Replacing Drivers Door Power Window Motor
Going to pick up a new power window motor (Drivers Front) anything else I need while im at the shop?
Everything appears to unbolt.. Unless I'm missing something
Cant WAIT to be able to open and close this window hahaha
Be careful removing the motor from the arm assembly. Depending on it's position it could be under a lot of spring PSI. Look closely i believe it needs to be removed when the arm is in full up position. Found this out the hard way
2ndly super strange that the motor isint grounded enough when it's all bolted in (without the spring). I thought I had a bad connection. Does the spring also ground the motor? Lol. Cause then I'm lost. Haha.
The motor grounds with the mounting bolts and then through the door hinges via the door sheet metal. Put a GND wire from the motor to the car body or to the battery and see what happens.
Thanks Yellowstatue... just got back from the garage... Yeah, I found that when the car was painted they laid it on thick, ha.. Door was not grounded at all... So instead of sanding down and making contact that way, I ran a grounding wire thru the door harness.. all works fine...
Its more frustrating that I didn't check that first because 3 "seasoned" mechanics told me that the motor was definitely no good... So after the fact I went and tested the old motor and it works fine... I believe they thought the two prongs on the motor were +/- and not +/+..
Still don't think I have the spring in the regulator correctly, but it goes up and down...
Napoleon1991
September 24th, 2013 09:21 AM
Bluemeanie
November 17th, 2011 09:32 PM
