67 442
Old April 12th, 2015, 08:10 AM
Thomas Simcich's Avatar
67 442
How do you verify that a 67 442 is really a 442? What is the difference between a 442 and a Cutlass for 67?
Thomas Simcich is offline
Old April 12th, 2015, 08:24 AM
lemoldsnut's Avatar
What is the vin and cowl tag. If built at the Fremont plant will be harder to authenticate
Email me direct i will do my best to help you
Lemoldsnut@aol. Com
Larry
lemoldsnut is offline
Old September 11th, 2015, 12:24 PM
new to this's Avatar
Another way is to remove the inner rear passenger courtesy lamps. The Cutlass models had a decorative emblem on the outside of the car. There will be a spot (Hole or filler) that you can see when the light is removed. If there is hole/filler it is/was a Cutlass. The 442 did NOT have this emblem, so no hole.
new to this is offline
Old September 12th, 2015, 12:07 PM
lemoldsnut's Avatar
Yes that and does it have one or two fuel lines?
Old November 5th, 2015, 01:05 PM
Registered car nut
nonhog's Avatar
So a 442 would have 2?
I have a line on a 67 442 project, nice to know if its the real deal.
nonhog is offline
Old November 6th, 2015, 03:35 AM
lemoldsnut's Avatar
A 442 has two fuel lines factory but so does a turnpike cruiser. Either way factory 400 E block both would have two fuel lines. A 330 car would not. If the car was built in Lansing it would have the 5V code on the cowl tag if Fremont then no 5V and harder to tell.
Old November 6th, 2015, 07:06 AM
67s were also built in Framingham.
joe_padavano is online now
Old November 6th, 2015, 08:41 PM
steverw's Avatar
Also boxed rear lower rear control arms, but they could be added. Anti sway bars?
steverw is offline
Old November 7th, 2015, 03:38 AM
lemoldsnut's Avatar
67 Cutlass Supreme cars had on the C pillar the C/S emblem. this was not there on 442 cars. If you suspect a car is a clone take the inside dome light lens off and the two screws that hold it in place and look inside the C pillar. You can see if the holes from that emblem have been filled. If they have been filled it could be a clone and not a real 442.
