1965 442 Dash Question
I'm back to work on my avatar vehicle. Looking at this great hole in the dash. It was a factory A/C car so it has the chrome vents in the dash on each end. What I'm concerned about is this opening in the center of the dash, down low. It has some sort of bracket riveted to the lower dash. I was going to fill it somehow, but it occured to me, some air cars had center air vents.
Can anyone address this issue? I don't recall what the dash of my last 65 442 A/C car looked like. Maybe somebody put a bracket in for a stereo, but I'm just not sure.
Hey Dave I think that looks like where the could if mounted a radio if you like I can take a pic tomorrow of the hole in the dash if you need
The radio already has a spot. You can see it in the upper right of my picture. Where does that chrome piece go in the center of your picture? I don't seem to have one of those. Hmmm....
Dave, what your missing is the guts from the middle vent. That is the middle item in Justin's picture. Attached is a pictures from a 1964 Cutlass project car that's also an AC car. John
So you may need to do a little metal work Dave if the hole was cut out larger for something other than the vent.
John
Yes, I'm guessing somebody stuck a radio or booster or CD player in the hole. I'll have to carefully remove the bracket by drilling out the rivets, and keep my eyes peeled for a center A/C assembly. Don't want to totally damage it in case someone wants to switch back to A/C in the future. Could always make a delete plate, I suppose.
Thanks for the help guys. I'm back on track again.
Next, to figure out how to seal up the passenger side floor air........and on it goes! A regular kick panel doesn't cover the opening properly, and you guessed it, someone got rid of the stock air kick panels. I only have a set of non-A/C ones. Oh my.......
I agree with you Justin. At first I just thought it was missing the insides, but the frame on Dave's car is much wider and a different shape than what you and I have.
John
John
Hmmm.....looks like height-wise it might fit, but length-wise it's doomed. Might have to do a delete plate like I made up today for one of the firewall holes.
Before and after pictures from this morning.
I used metal about 1/16 inch thick. May not be pretty but strong, and keeps the engine compartment air out of the cabin.
I believe I may have to put a wanted ad out for a damaged or pitted one that's not too expensive.
Now you see why I don't get the BIG dollars for my old cars !!
did you keep any pics of it with dual fours and propane mixers?
