17" wheel fitment
Old Nov 15, 2007 | 03:22 PM
442 Guatemala's Avatar
Question 17" wheel fitment
Hi, im restoring my 1966 olds 442. I want to customize my car and Im thinking in installing a 17" boyd coddington junk yard dog wheels.
the problem that i have is that im not really sure if a 17X10 wheels with 275/40/17 tires will fit in the rear of the car? if yes what bakcspace and offset do i need? does anybody can give my and advice? the Junk yard dog wheel doesnt come in 17x9 only 17x8 and 17x10
Im thinking on 17x8 wheels with 245/45/17 tires for the front, is that a good choice?
thanks for any advice
Alex
Old Nov 15, 2007 | 03:40 PM
Alex
Your 245/45-17 fronts are only 25 3/4" in diameter. This is exactly the same width and outside diameter as a 245/60-14. I've run those tires on the front of various A-body cars with no problems, but you MUST have near zero offset. If anything, these tires will be tool small in diameter and will look out of place in the wheelwell. These cars were designed to use tires about 27" in diameter. Cut one coil off the front springs and these will look good.
The 275/40-17 are the same 25 3/4" outside diameter. Again, with zero offset these will fit fine. The problem is the diameter. You'll have a lot of daylight between the tire and the wheel opening. Personally I don't think that looks very good. I usually run 255/60-15s on the rear, which are just over 27" in diameter. These do a real nice job of filling the wheel openings.
Old Nov 16, 2007 | 10:16 AM
Question 17" wheels fitting
Thanks JP for the advice.
But Im not clear yet if the 17X10 wheels with zero offset wiil fit my car?
5.5" of backspace is good?
I have another question, I put front disc brake in my car, the 17x8 wheel with zero offset still working??
I already lower my car 1" you think still too high?
thanks
Alex
Old Nov 16, 2007 | 07:21 PM
$tryker's Avatar
442 Guatemala,
Your 17x10 wheels will work with 5.5" backspace. I currently use these on my "67", along with BF Goodrich 275/40/17's. The car is lowered 1", and the fit/stance is great! The vehicle uses a disk brake set-up from a "71" Monte Carlo with 8" rims (same backspace).
I believe you chose well.
I have read, it is possible for 6" backspacing if you want to go for wider skins. Not 100% sure, someone can chime in for that. Good luck
Mark
Old Nov 21, 2007 | 07:56 PM
Smile 17" wheels fitment
Hello
Finnally I decide to buy the boyd coddington junk Yard Dog wheels for my car
I buy
Front: 17x8, 0 offset, and 245/45/17 tires
Rear: 17x10, +6mm offset, and 275/40/17 tires
the problem is that the wheels are custom made, so I have to wait 6 weeks until I have them...
I hope they fit fine, thanks for the help
Any suggestions is welcome
Alex
Old Dec 9, 2007 | 12:01 PM
dkatz's Avatar
Down South
Original size
What was the original size of the lods 442 1970. I'm running hopelessly small tires. 205/70/14. they are about 2" short of 27". What is the closest stock size i can get for the 14" rims.
Old Dec 9, 2007 | 12:23 PM
kevinkpk's Avatar
I believe they are (where) a G70/14. I think the G70 is changed nowadays, but width is you're choice. Tire shop should convert to todays tire size/reference.
Old Dec 10, 2007 | 08:22 AM
Wheel and tire fitment
Hi, you can check at http://cokertire.com/ you will find what are the original size of the tire, and other suggested sizes for your car.
hope this help
Alex
rcdynamic88
Wheels and Tires
Jan 19, 2020 09:42 AM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
Jocko124
Jun 21, 2011 08:55 PM
steve terry
Wheels and Tires
Jan 29, 2010 12:15 PM
