Click Here
need help with tire size
Old Oct 12, 2012 | 06:41 PM
72cutlassolds's Avatar
whats up classicolds world just had a question about tires size. I have a 72 cutlass supreme and im finally at the part where i need tires i got 15/7 ralleys i want some nice beefy looking size in the back and just a lil smaller in the front with that being said how should i ask for that set up who knows a nice tire set up pics would be nice thanks for reading
Old Oct 12, 2012 | 06:49 PM
hurst68olds's Avatar
245/60/15 front & 275/60/15 rear usually works well
Old Oct 12, 2012 | 07:09 PM
RetroRanger's Avatar
72 Olds CS
I roll 255-60-15s at all four corners on SSIIIs 72 supreme
Old Oct 12, 2012 | 07:25 PM
oldsmobiledave's Avatar
more info
Need more info...how do you use your car & what are is the driveline package...engine?...trans?...Rear gear ratio?
I sure would not pick a 275 60 15 tire out back if I had a 350 2bbl with a T350 & a 2.56 open diff.....see my point?
Old Oct 12, 2012 | 10:06 PM
actually, I don't see your point .....
Most probable original tire was G78-14 = ~ 27.1" diameter
275/60/15 = ~ 28.0" diameter
Standard engine in a Cutlas Supreme was a 350 4bbl & 2.73s were the lowest numerical gear in '72 (& yes I understand that many things can be changed in 40 years)
Old Oct 12, 2012 | 10:31 PM
i have a 350 rocket four barrel carb i dont race or nothing well i never drove the car im restoring it but its a 350 th350 tranny stock 10 bolt rearend
Old Oct 13, 2012 | 10:11 AM
QMaster's Avatar
I have 245/60-15s at all four corners.
Old Oct 13, 2012 | 10:35 AM
1970supremevert's Avatar
I am running 255-60-15 rear , 225-70-15 up frt , speedo error 5 mph slower that actual speed 71 supreme
Old Oct 14, 2012 | 06:30 AM
jerseyjoe's Avatar
I have 245-60-15 - 15-7 Rims on my 68. No issues with rubbing, car runs fine on them. I have a limited slip 2.78 rear so no fun with burnouts...
Uncle Hulka
Wheels and Tires
Apr 30, 2014 04:45 AM
jkoester122
Jun 7, 2011 07:25 AM
kane
Ninety-Eight
Jun 2, 2011 02:13 PM
denf221
Wheels and Tires
Feb 1, 2010 09:03 AM
nmtt92
Mar 16, 2009 10:15 AM
