Wheel/tire fit 71 Cutlass -S
Can anyone comment on whether or not a 10 in. rear wheel will fit on a 71 Cutlass-S with a chevy 12 bolt rear end (I've read the 12 bolt rear end is 1" wider than the factory Olds 10 bolt)? ...I found an old set of Western aluminum slots... backs are 15x10, fronts are 15x8 (3 1/2 in. back spacing)...
Looking for tire size suggestions that will work yet clear, keeping in mind after market disc brakes as well...
Thanks!
Thanks!
Thanks!
Thanks!
10" wide wheels will fit fine until you decide to put tires on them, then the size of the TIRES will determine whether the tires clear or not. If you are saying that both the 8" and 10" wheels have 3.5" backspacing, then neither will allow the tires to clear. You want as close to zero offset as possible. That's going to be about 4.25" backspacing for 8" wide wheels and 5.25" backspacing for 10" wide wheels.
tmaleck
August 15th, 2021 08:17 AM
oldsguybry
Wheels and Tires
21
February 27th, 2013 08:31 AM
plee3 64Olds
Wheels and Tires
February 27th, 2012 01:18 PM
bigjaythe1st
Wheels and Tires
February 22nd, 2012 01:37 PM
