Click Here
What size tire for 15x7 ssII rims?
Old August 13th, 2010, 08:59 PM
erke88's Avatar
Hello, I'm currently restoring some 15x7 ssII rims for a 1971 Cutlass Supreme. Was curious as to what size tires would fill up the fenderwell and give me enough meat on them without looking funky. I'm probably gonna end up going with BF Goodrich Radial T/A's. I was thinking about the size P235/70/R15. Was also thinking about P255/70/R15 but I don't know if they will rub. Please give me insight as to what you have found to work and look the best. Pictures would be much appreciated. Thanks! Also, what is the max overall diameter of rim and tire and also the max section width on measuring rim width I could go with? For example, the P235/70/R15 I am looking at have a section width (on measuring rim)of 9.5". Thanks for your help! Remember pictures appreciated. Never realized how hard finding the perfect set of tires really is haha
erke88 is offline
Old August 13th, 2010, 09:08 PM
245-60X15's look good.
1969w3155 is offline
Old August 13th, 2010, 09:15 PM
245-60x15's
On my '71 Supreme.
Old August 14th, 2010, 06:24 AM
2blu442's Avatar
Yes I agree with the 245 60X15's. They look nice and will fit without any problems.
2blu442 is offline
Old August 14th, 2010, 06:40 AM
STOP call'n it a Chevelle
arodenhiser's Avatar
Yes I too agree with the 245 60X15's. They look nice and will fit without any problems.
I had 255 on the rear and a full trunk and about 4-5 passengers I got some rubbing on the bumps.
I like the BFG's too, they look nice and smoke really well.
Adam
arodenhiser is offline
Old August 15th, 2010, 11:38 AM
MX442's Avatar
What rear gear do you have? 70 series rears are 29" and will look too tall and bulky. If you like the big/little look, 275/60/15 rear, 245/60/15 or 225/70/15 front fronts are very popular. Another good combo slightly smaller is 255/60/15 rear, 235/60/15. Or if you want all the same size, 245/60's like others mentioned. Check the team cheve!!e forum, lots of guys post their tire pics.
The 68 in my sig has 275/60 & 245/60. I will soon be doing a set of 15x7 SSII with 255/60/15, 235/60/15.
MX442 is offline
Old August 15th, 2010, 01:18 PM
One of None W-31
71 Cutlass's Avatar
Yep, I also run the 245/60/15
71 Cutlass is offline
Old August 17th, 2010, 03:56 PM
Classic GM Fan
mv213's Avatar
I just got my 255/60 -15(rear) and 235/60-15 (fronts) back from the tire shop where they mounted Cooper Cobra's on new reproduction Rally II's. I should be able to get them on the car this weekend. I really wanted Dunlop GT Qualifiers but no longer available in RWL in the classic sizes.
mv213 is offline
Old August 21st, 2010, 01:04 PM
Smallhurst's Avatar
Go old school with bigs and littles-- F60-15 and L60-15 Goodyear Polyglas!!!!!
Smallhurst is offline
Old August 21st, 2010, 01:08 PM
MN71W30's Avatar
I think the 275/60/15's look the best on the back of a 70-72 Cutlass.
MN71W30 is offline
Old August 21st, 2010, 01:55 PM
stevengerard's Avatar
the L60 is rated for the 10 rim does it work on the 7 inch stockers?
stevengerard is offline
Old August 21st, 2010, 10:11 PM
Smallhurst's Avatar
Yes. It will fit on a 7 inch rim with no problem.
Old August 31st, 2010, 10:06 PM
442much's Avatar
I went back to factory size G70R 15 or 225 70R 15. When buying tires look for the numbers after "DOT" It might say something like 1610. The 16 means the tire was build in the 16th week of the year. The "10" is the year. Don't buy old tires that have never been used. Use this guide to know that you are buying new and not helping the shop dump its older tires. It's also a safety matter.
442much is offline
Old September 1st, 2010, 07:01 AM
MN71W30's Avatar
Great tip!
MN71W30 is offline
Old September 2nd, 2010, 06:48 AM
Blk71SX's Avatar
after decades of radials, the performance of fiberglass belted tires will be disappointing
best to have wheel width equal to tread width
Blk71SX is offline
Old October 13th, 2010, 02:20 AM
q8442's Avatar
245x60x15 ON MY 71 442
q8442 is offline
Old October 13th, 2010, 06:44 AM
P275-60's on rear with P225-70's on front, awesome!!!!!
oldcutlass is online now
Old January 15th, 2011, 07:08 PM
GM's Best Division
UnkleMarc455's Avatar
Anyone run p295-50-15 on 8 inch ralleys, I saw some on a GSX at Barret Jackson last year and they looked great. I like the balloon look personally!
UnkleMarc455 is offline
Old January 15th, 2011, 09:13 PM
Senior Moment Member
z11375ss's Avatar
245/15/60, my choice.
By z11375ss at 2008-06-29
z11375ss is online now
Old March 12th, 2019, 01:52 PM
72CutlassTX's Avatar
I have original 14" rally wheels on my '72 CS and have found that tire options are VERY limited. So I ordered after-market 15" SSI rally wheels and now have a ton of options. Will most likely go with the 225/70/15 in order to get more height for the car. Thought about the 235/70/15 as well but near 3" in height gained could create some rubbing problems.
72CutlassTX is offline
Old March 30th, 2020, 08:44 PM
Kolby66's Avatar
hello, what size tires did you end up with? I am looking at the 235/70-R15s all the way around. Thanks
Kolby66 is offline
Old March 30th, 2020, 08:45 PM
Kolby66's Avatar
Hello, What size tire did you end up going with?
Kolby66 is offline
Old March 30th, 2020, 10:48 PM
What vehicle do you have?
Fun71 is online now
Old March 31st, 2020, 08:04 AM
atkinsom's Avatar
I have a 1969 Cutlass S Hardtop with 455 and dual exhaust. The tires below are what I'm using...great tires for the price and look awesome to me with plenty of compliments from other Olds guys up here in the Great White North. In the rear it just barely clears but that's because the exhaust I got from PYPES wasn't bent correctly and I didn't want to go through the hassle of returning. I had to do some manual heating and bending but got it to where I needed. Anyway with proper exhaust bends in the back you'll have plenty of clearance. Good luck.
Front
Cooper Tires - Cobra Radial G/T - P215/70R15
Rear
Cooper Tires - Cobra Radial G/T - P255/60R15
atkinsom is offline
drop top olds
May 2nd, 2014 01:19 PM
oldsguybry
Wheels and Tires
21
February 27th, 2013 08:31 AM
eddie160
November 7th, 2012 02:57 PM
nonhog
Wheels and Tires
February 22nd, 2012 11:00 AM
71cutty
April 1st, 2010 10:25 PM
Quick Reply: What size tire for 15x7 ssII rims?
