Tires for 65 F85 with 17" rims
I was wondering if anyone had some input on the tire size best to put on a 17x7" rim for a 1965 f85. I know there are alot of people who have had issues with rubbing or scraping the wheel wells due to having too tall of a tire.
The specific rim I'd like to use is this one:
http://www.ebay.com/itm/17-inch-17x7...c5a0d&vxp=mtr7
There is also a 15x7" available if the 17" is just not doable, but I would like to have the 17" with a lower profile tire, similar to the attached image
If anyone has any input that would be great, Thank you.
I have 17x8 with 0 offset 205/50/17 in front and 17x9.5. +6 offset still playing with tires as I get used ones for free at times I know it's not wide enough but has 235/45/17 rear
My front rub when I am turning hard one way if I never max out its fine
This may not be of much help but Im almost certain with a std. ride height, I can get a 255/60R x15 drag radial on the rear and 215/70R x15 on the front with no rub issues. These are on GM big car 15x7 steelies. However there is complete Hotchkis suspension on the car with the B-Body spindle upgrade that takes under steer-lean out when cornering hard on these A-body cars. Just some thoughts.....
I don't know what will fit in that body style, but a good size for that rim would be 235/55/17. About the same overall height as a 215/70/15, for reference.
If you wanted to go with a slightly lower profile, I'd suggest 245/50/17, but that should be used on an 8" wide rim.
Also, with lower profile tires most people like to lower the car a touch as well. Even if the overall diameter of a low profile set of 17" wheels & tires is the same as a set of 15"s, the wheel gap (between top of the tire and and fender or quarter panel) just looks bigger and less aesthetically pleasing. But that is all personal preference.
oldsguybry
Wheels and Tires
19
February 16th, 2013 09:14 PM
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
