Staggered Look
Staggered Look
Trying to get that staggered look. I like my original 14 x 6 rallys. Thinking 235 60r14 on rear and 215 60r14 on front. Would this be a noticable difference. How would it effect handling. If you have pics of your setup, please post.
Car is a 79 cutlass supreme but i dont care what the pics are of.
not much of a difference 20mm (less than an inch) and you really only see the outside of the tires so 10mm or about 3/8 of an inch.
you may try to find some 15x7 rally wheels and run 15s and 14s that would give you a lot more options
Or you could run a P205/70R14 8.23 width on a 6" rim in the front.
i run 14 x 7 up from with 215 70 14 up front and 15 in the rear these tires where bfg drag radials 275 50 15 . You might be able to find a realy wide 14 from mickey thompson on thier indy profile i have seen guys run the staggered look on 14's the best look was with the m/t tire or hoosier qicktime dot 275 55 14
Curts1970cutlass
February 25th, 2013 01:10 PM
