Click Here
Creaking SS1 trim rings
Old April 13th, 2020, 08:57 AM
Warren Seale's Avatar
The trim rings on my SS1 wheels are creaking when making turns. How can I stop this without doing anything that will cause them to slip? Will simply bending the grip clips out prevent it?
Warren Seale is offline
Old April 26th, 2020, 06:55 AM
I deleted your other duplicate thread. You can try to bend the tabs a bit, just make sure they are bent out the same or they will look like hula hoops going down the road. What I've done years ago is to wrap 2 layers vinyl electrical tape around the whole trim ring along the tabs.
oldcutlass is offline
Old April 26th, 2020, 07:15 AM
My442's Avatar
If you can hear the trim rings creaking, your car is not loud enough!!!!
My442 is offline
Old April 27th, 2020, 06:23 AM
Originally Posted by my442
if you can hear the trim rings creaking, your car is not loud enough!!!!
:d
Old April 27th, 2020, 06:25 AM
I'll try the bending trick. I've done the tape thing but this caused the trim rings to slip and rotate position on the wheel.
Cruzinbill
August 28th, 2019 10:50 AM
Del70
November 1st, 2017 02:44 PM
November 1st, 2017 12:08 PM
JOHNNYOLDS442
October 20th, 2015 07:34 AM
bummerino
March 14th, 2010 07:53 PM
Quick Reply: Creaking SS1 trim rings
