56 Olds 88 2Dr Hardtop rear quater panel
Old December 1st, 2015, 04:17 PM
monte56's Avatar
Trying to find rear qtr panels for 56 Olds 88 2dr hardtop...looking for the section between the door and wheel well. Found some from a 54. Anyone know whether they will work? Thanks
monte56 is offline
Old December 1st, 2015, 04:31 PM
I moved your thread to the vintage section section. Hopefully these guys can answer your question.
oldcutlass is offline
Old December 1st, 2015, 06:50 PM
monte56's Avatar
Thanks..looking for info on the part compatibility.
monte56 is offline
Old December 1st, 2015, 09:03 PM
Proud Viet Nam Veteran
redoldsman's Avatar
I think that front part of the quarter panel is probably the same but can't say 100%.
redoldsman is online now
Old December 2nd, 2015, 05:23 AM
Rocketowner's Avatar
X2 .54-56 I believe should work ,but what I believe + $1 will get you a Sweet Tea @Mc Donald's. The problem area would be the area around the perimeter of of the fender skirt.The fender skirts and wheel opening on '56 Olds are the same as '55 4dr. Hardtop,but different from '54 And '55 2 dr. Hardtop. Hope you can find exactly what you need from a '56,but if not send me a picture of the damaged area,and we can go from there. Do you have access to a '57 Bel Air 2 dr. that you could do some comparing and measuring.Rustrepair.com has these panels for a '57 Bel Air 2 dr for under $100 each.Just might take very little modifying.
Rocketowner is offline
Old December 3rd, 2015, 11:01 AM
monte56's Avatar
Hi, I attached a sketch and pic of the rear qtr. This side of the car has been cut out the other side has not. Thanks for the help
monte56 is offline
Old December 3rd, 2015, 03:38 PM
redoldsman's Avatar
The wheelbase opening is different on the 56. The 54 and 55 are the same.
Old December 3rd, 2015, 04:28 PM
The actual wheel lip area (only about 2" wide)is the same as a '55 4 dr. Hardtop (both ('56 2 dr. hardtop and '55 4 door hardtop use the same fender skirts.Then you would have to fabricate the the flat 20" or so out of sheet metal.I would recommend you check out www.rustrepair.com and look at the ones for 1957 Bel Air 2 dr..AT under $100, it might save a lot of time. Larry
Old December 3rd, 2015, 08:47 PM
redoldsman's Avatar
Looks like you are going to need rocker panels too. I think I have a repro set of those if you do. You might try Dessert Valley Auto Parts or CTC Auto Ranch for the quarter panel. They won't be cheap but will probably be less than all the metal fab required.
Old December 5th, 2015, 08:05 AM
twintracks's Avatar
I restored a '56 Chevy about 20 years ago. It sure was nice to pick parts from a catalog when needed. Only real (crazy) men tear into an old Oldsmobile.
twintracks is offline
Old December 5th, 2015, 08:38 AM
Tedd Thompson's Avatar
Sometimes a parts car is your best solution especially if you need additional parts. Unfortunately the parts that you need are the parts that rust out first.... Tedd
Tedd Thompson is offline
Charly9g
June 3rd, 2015 06:09 PM
steverw
Body work
December 7th, 2014 12:47 PM
mighty mouse
April 11th, 2014 08:05 PM
Neo1874
October 9th, 2006 07:18 PM
<luvmyolds>
January 17th, 2004 10:57 AM
Quick Reply: 56 Olds 88 2Dr Hardtop rear quater panel
