1948 Oldsmobile club coupe door handle escutcheons
Old June 28th, 2015, 11:42 AM
Jims48's Avatar
I have a 48 club coupe. A week ago, I find the interior door handle and escutcheon on the floor of the car. Inside the escutcheon was part of the escutcheon spring. It appears to have broken off. The spring I pulled out does not look like your typical escutcheon spring with a narrow taper on one end and the one that came off fits into the escutcheon. Anyone know where I can get replacement springs. Any assistance would be appreciated.
Jims48 is offline
Old June 29th, 2015, 08:38 AM
47 Convertible's Avatar
Try Fusicks. Their item 1267. They say it fits all 1937 - 1960 door, vent and window handles. Its called a tension spring. $3.00 ea plus shipping. I'd get all new ones since shipping half a dozen isn't much more than one. 860-623-1589 or www.fusick.com
Jerry
47 Convertible is offline
Old June 30th, 2015, 10:57 AM
Jims48's Avatar
Thanks Jerry. I need to give them a call. The spring that broke off fits into the escutcheon and I want to make sure these springs I order will fit up there. I will post back when I find out.
Jims48 is offline
Old October 1st, 2015, 04:36 AM
Jims48's Avatar
door handle escutcheon spring
I ordered the tension springs from Fusick. The diameter was too small. They are 13/16" and do not fit inside the larger diameter escutcheon, which is about 1" in diameter. Anyone else experience this problem?
Jims48 is offline
Old October 1st, 2015, 03:31 PM
47OldsWy's Avatar
Hope this will help you. These are the ones off my 78 series 1947. There is a spring inside the escutcheon, then there is a tension spring. The tension spring narrow end does measure 13/16". The larger end goes towards the escutcheon and the narrow end goes towards the door (tension spring is behind the door panel).
47OldsWy is offline
Old October 2nd, 2015, 07:09 AM
Jims48's Avatar
Smile
Yes, the pictures help quite a bit. I do have two springs, but the one that fits inside the escutcheon is quite a bit longer than the one shown in the picture. Now that I see how it is supposed to be, I think I can figure something out. I didn't want to start taking apart the other handles to create more headaches.
Thanks for your help.
Jim
Jims48 is offline
KZ442
June 6th, 2015 10:08 PM
BAFRAYD
July 24th, 2014 07:59 PM
Jims48
November 15th, 2012 04:01 PM
costpenn
June 16th, 2012 01:05 PM
citcapp
January 21st, 2009 05:17 AM
Quick Reply: 1948 Oldsmobile club coupe door handle escutcheons
