Flywheel tool
Old September 1st, 2013, 03:39 PM
Olds Scott's Avatar
Flywheel tool
What is the best way to hold the flywheel from turning when installing the harmonic balancer on my 324 engine when on an engine stand?
Olds Scott is offline
svnt442's Avatar
Something like this:
svnt442 is offline
Old September 1st, 2013, 03:50 PM
Olds Scott's Avatar
Was thinking of some sort of flywheel tooth tool that would bolt to bellhousing some way. Kent Moore mad a lot of these tools but which one for a 324?
Old September 1st, 2013, 04:00 PM
Octania's Avatar
not familiar with the 324 much but I generally have used vice grips clamped onto a junker flexplate. Butt up against the stand
Octania is offline
Old September 1st, 2013, 08:18 PM
Tedd Thompson's Avatar
I think we just stuck a small hooked crowbar(two feet long)between the flex plate and bellhousing catching a tooth. I don't remember it being a major problem....Tedd
Tedd Thompson is offline
Old September 1st, 2013, 08:23 PM
Or a long screw driver on the flex plate or torque converter bolts.
oldcutlass is online now
Old September 2nd, 2013, 12:15 AM
'87 Delta 88 Royale
rustyroger's Avatar
An old valve heated and bent 90 degrees works just fine
Roger.
rustyroger is offline
Old September 2nd, 2013, 07:31 AM
Trying to remember member
wmachine's Avatar
How about the old school trick of taking out a spark plug and feeding some rope into the cylinder with the piston toward the bottom of the stroke. Obviously keep a fair amount out.
wmachine is offline
Old September 2nd, 2013, 07:48 AM
Or use a impact wrench,I think thats how mine came off.....Tedd
Kaline
April 18th, 2022 03:35 PM
scrappie
February 11th, 2013 09:04 AM
Dan Wirth
November 12th, 2009 10:38 PM
tim72
Drivetrain/Differentials
April 3rd, 2009 09:00 AM
jeffabarber
August 27th, 2008 07:37 PM
Quick Reply: Flywheel tool
