57 door hinge pins?
Old May 25th, 2022, 07:17 AM
chopolds's Avatar
57 door hinge pins?
Anyone know if there are hinge pins, and bushings available for 57 Olds 98? I'm sure I can find something that works, searching the internet for hours, but maybe someone else has done the research?
chopolds is offline
Old May 25th, 2022, 10:19 PM
Phantom Phixer
Charlie Jones's Avatar
I looked up the part numbers in the Olds parts catalog. Then I looked on GM Parts Wiki to see if they were used on Chevrolet.
Front door upper #4156402 also used on 53 & 54 Chevy passenger.
Front door lower #3797175 also used on 53 thru 57 Chevy passenger and 53 thru 63 Corvette.
Rear door upper #4301327 also used on 49 thru 63 Chevy passenger ( exc. Delray & Yeoman.)
Rear door lower # 4125658 also used on 53 & 54 Chevy passenger rear door and 42 thru 48 passenger front door .
Hinge bushings # 4110660 also used on 31 thru 63 Chevy passenger and 56 thru 62 Corvette.
Charlie Jones is offline
Old May 26th, 2022, 05:41 AM
chopolds's Avatar
Wow! Thanks Charlie!
chopolds is offline
Old May 26th, 2022, 05:57 AM
Nomadoc's Avatar
I can’t find the receipt but I’m pretty confident that the bushings/pin set I used was part # GM-1081K from fillingstation.com
Bill
Nomadoc is offline
tkcutlass
February 17th, 2022 11:12 AM
72455
September 28th, 2018 02:49 AM
tcolt
November 4th, 2017 10:53 PM
Bfg
August 13th, 2014 05:17 PM
croozer
August 15th, 2011 01:09 AM
Quick Reply: 57 door hinge pins?
