Choke Heat Tube
Old March 15th, 2017, 04:51 PM
stephenca118's Avatar
Choke Heat Tube
Good day all,
While cleaning the intake manifold on this 58 371, I see that the choke heat tube is gone. How necessary is it?
Stephen
stephenca118 is offline
Old March 15th, 2017, 06:40 PM
Olds Scott's Avatar
Fusick has them, they are necessary for stock carburetor.
Olds Scott is offline
Old March 15th, 2017, 06:41 PM
Rocketowner's Avatar
If you run the car in extremely cold weather you probably need to replace it ,or you could go to an electric choke. The heat coming through the bottom of carb keeps gas from crystalizing ,though ,in extremely cold weather. Best of luck, Larry
Rocketowner is offline
Old March 16th, 2017, 06:24 AM
Thank you for your feedback. Someone did a mickey mouse universal choke stove on the exhaust manifold. I will see if I can replace the manifold tube.
Thanks again,
Stephen
kad36
February 6th, 2017 03:35 AM
88hurstolds
November 14th, 2014 12:07 PM
dingusboy
March 8th, 2014 07:09 AM
74droptop
April 19th, 2011 01:37 PM
kgenesse
February 21st, 2010 06:00 AM
Quick Reply: Choke Heat Tube
