What steering wheels fit a '48?
Old June 28th, 2015, 09:31 AM
zii
zii's Avatar
I have no idea what steering wheels might fit a 1948 Series 66.
Do they use the same splines as something else?
Once I get another steering gear on the car, the original wheel will be way too large so I'll probably get some aftermarket steering wheel instead.
zii is offline
Old June 28th, 2015, 11:01 AM
47 Convertible's Avatar
Steering Wheel on '48
___________________________
If you are talking about changing out the column I'd suggest a GM column from the 70s or 80s then just about any GM or aftermarket wheel will fit. The aftermarket manufacturers make kits to adapt their steering wheel to splines if necessary. My 47 has a mid-70s Pontiac column and while its still a non-driver I've got a steering wheel from a 70s Chevy van. Not fancy nor a keeper but it does to move it around the shop or up and down the driveway for brake checks and such.
You are correct that the original wheel is too large once you go to something besides manual steering on the original column. It would work but just looks and feels awkward. What you might consider if you like the look of the original is cutting it down to a smaller diameter and re-casting the outside rim of the steering wheel or having it done. There is quite a bit of information on the Internet about this option. I'm still considering it and will see when other major expenses like paint and upholstery are done whether the budget will allow it. My original steering wheel does fit on my later model GM column splines.
Jerry
47 Convertible is offline
Old June 28th, 2015, 12:22 PM
zii
zii's Avatar
What is a "later model" in this context?
zii is offline
Old June 28th, 2015, 02:06 PM
More Steering wheel information
By "later model" I meant newer. Poor choice of words on my part.
My steering column is from a 1970s Pontiac according to a Portland, Oregon man, Terry Sorvik, who buys and sells, repairs and installs GM columns including tilt columns. He knows more about them than I ever will. When the time comes that you might need some advice or parts for a used factory GM steering column he would be one source. His email: tonkdejur@earthlink.net
New aftermarket columns are available from companies like Flaming River and some others and for owners outside the USA and Canada, they might be a better option as I imagine there are not wrecking yards full of old GM cars where you live that can be a source of used parts.
Jerry
tmaleck
August 15th, 2021 08:17 AM
WTony
January 15th, 2011 07:53 PM
Danielle's 71
April 14th, 2009 07:32 AM
87customcruiser
Vista Cruiser & Wagons
February 28th, 2009 06:57 PM
BobM
December 31st, 2007 06:15 AM
Quick Reply: What steering wheels fit a '48?
