Sound Deadener for '55 S88?
Old April 26th, 2023, 11:45 AM
Jen R - '55 Super 88
JenR8r88's Avatar
My Olds never had any carpet, kick panels, etc. since I've had it - my Dad must have had a reason to taking it down to the metal floor ¯\_ (ツ)_/¯... Do I need to put anything down underneath the carpet kit that I've purchased? I've seen some "Sound Deadener" kits on Rock Auto & eBay (CollectorsAutoSupply.com) but am unsure and looking for input/guidance from the experts on CO. Thanks!!
JenR8r88 is offline
Old April 27th, 2023, 08:52 AM
ub2693v's Avatar
I bought a carpet kit for my 1955 Olds '98 from Rockauto, it is made by a company called ACC, it was priced great and the sound deadening is glued to the underside of the carpet just like the original.
ub2693v is offline
Old April 27th, 2023, 09:02 AM
FYI
ACC produces/manufactures most of the carpet supplies for the majority of the automotive resale outlets (i.e. Rock Auto, Legendary, etc.). They produce a quality product.
Additional info. can be found here...
https://www.accmats.com/about/
Vintage Chief is offline
Old April 27th, 2023, 09:31 AM
JenR8r88's Avatar
FYI
Hi Norm, I purchased a carpet kit identical to the one sold on accmats and the pieces do have something like a carpet pad attached just as @ub2693v indicated in his post. BUT accmats also lists Sound Deadeners in the same section. Do I use both?? My interior floor is nothing but metal. https://www.accmats.com/commerce/195...eadener/14392/
JenR8r88 is offline
Old April 27th, 2023, 09:52 AM
Jen - Excellent question I am unable to answer. I suspect you can use both. I'd call ACC and ask them. 800-352-8216
Old April 27th, 2023, 01:04 PM
OLDSter Ralph's Avatar
Jen, the carpet kit you purchased is probably good enough. The carpet kits could be used on cars being restored or customized. The basic carpet lit would be more for stock automobiles. For a customized vehicle with different exhaust and A/C installed, the extra sound deadener/insulation could be used to reduce sound and heat from outside the car.
Jen, something to think about...... back in those days, carpet was an extra cost option. Many cars had a rubber mat that covered the floors instead of carpet. I am not talking about floor mats, I am saying rubber mat material in place of the carpet. "Salesman's cars" usually were ordered with the rubber because it could be kept cleaner. A salesman carried his "samples cases" inside the car, and was in and out of his car several times a day in all kinds of weather.
A "Salesman's car" was generally the cheapest model with no, or very few options. They had black wall tires, small hub caps, and many times a manual transmission.
OLDSter Ralph is offline
Old April 27th, 2023, 01:40 PM
JenR8r88's Avatar
Thank you Ralph! My parents owned car washes so I would assume my Dad ruined the carpeting with the carwash environment that he just took them out...especially since it didn't have any kick panels either. I have one childhood memory of sitting in the back seat being tall enough to only see the window crank handle and the arm rest materials but none of the front or floor until I decided at 15 that I wanted to drive it.
Thank you for your guidance. My last question on this would be that since I live in Phoenix, and it's REALLY hot here, would that add extra insulation might benefit me? I do not have A/C in the car.
JenR8r88 is offline
Old April 27th, 2023, 02:02 PM
Jen, I am not sure how much "Dynamat" on the floorboard and footwells would help on a non-A/C car. I have wondered about using it in the roof under the headliner. Maybe others can chime in with their thoughts.
frozencaveman
April 1st, 2020 09:00 PM
dhimme1045
September 29th, 2019 09:39 AM
Bowtie-Bri
January 9th, 2018 02:24 PM
bulldogs#10
June 22nd, 2015 11:21 AM
dhartley72
October 29th, 2010 05:29 AM
Quick Reply: Sound Deadener for '55 S88?
