no brake lights
Old May 8th, 2017, 08:54 AM
friskyjake67's Avatar
no brake lights
Hi Folks Yesterday I drove my friends 1957 fiesta wagon to a big car show & as I,m following him in his 1955 98 2 door hardtop, I noticed he had brake lites working when he used his signal lites [either r side or l side] . But as he came to a regular stop he had no brake lites. Any ideas where to start looking for the problem? Thank you in advance. Friskyjake67
friskyjake67 is offline
Old May 8th, 2017, 03:16 PM
Rocketowner's Avatar
Well the same filament in the bulbs works both turn signals and brake lights,so it wouldn't be the bulbs. Has to be in the wiring, but where I would not know. Thanks
Rocketowner is offline
Old May 8th, 2017, 03:43 PM
Check to see if there is voltage at the brake light switch white wire at the steering column connector with the brake pedal depressed. If so then its probably a bad turn signal switch.
oldcutlass is online now
Old May 8th, 2017, 05:11 PM
Tedd Thompson's Avatar
It's not uncommon for there to be a poor ground do to corrosion between the tail light base and the body of the car. Even though there are two large bolts holding the light on and they can be tight there is nothing to keep moisture out and it corrodes there.
On a second note I have seen this happen several times but never two at the same time so maybe there is another issue..... Tedd
Tedd Thompson is offline
Old May 8th, 2017, 05:37 PM
Proud Viet Nam Veteran
redoldsman's Avatar
I have the same problem right now on my 54. The interior lights and the brake lights are on the same fuse. Unfortunately my fuse is good so I have an electrical gremlin somewhere.
redoldsman is offline
907delta88
April 11th, 2014 12:33 AM
65droptop442
May 5th, 2013 12:21 PM
oldstuff
September 13th, 2011 08:03 AM
Del70
August 2nd, 2011 04:40 PM
Sid
September 10th, 2010 02:33 AM
Quick Reply: no brake lights
