how wide rims for a 56
Old July 15th, 2016, 07:31 AM
Sid
Sid's Avatar
How wide were the rims on the stock 56 olds , wonder if you could put 7 inch wide with no clearance problems does anyone know?
Thanks Sid
Sid is offline
Old July 15th, 2016, 07:37 AM
cmpcpro's Avatar
They were 15x5.5 or with the largest optional tire 15x6
cmpcpro is offline
Old July 15th, 2016, 06:43 PM
Tedd Thompson's Avatar
I have a set of chrome reversed wheels I used for a while on my 55. They were 8 inch in the back and 7 in the front. I ran a 235/60r/15 in the back and215/65r/15 in the front. The backs would rub if switched to the front and were very close on the rears but did not rub. I carried a 215/65r/15 as a spare.
Keep in mind that you can't rotate your tires and with skirts on the over sized tires the extra width doesn't show up much. I later wen't with 760/15 WW bias ply which looked great but followed every grove in the road and were tiresome on long trips. I now run 225/70r/15 with 3" wide whits and have no problems.
About the largest stock bias ply tire I have see on a stock rim is a 845/15.... Tedd
Tedd Thompson is offline
LJA72
January 31st, 2014 08:02 PM
grindlecrew
March 2nd, 2013 04:19 PM
CutlassLegend
Care and Appearance
August 6th, 2011 11:08 PM
Quick Reply: how wide rims for a 56
