57 or 58 carb to bellcrank to transmission linkage
Old September 22nd, 2017, 06:02 PM
yellow1301's Avatar
I am looking for the linkage from a 57 or 58 Olds beginning from the carb all the way down to the long transmission rod that hooks onto the side of the transmission. I also need the bell-crank that the linkage and throttle rods are hooked up to. The linkage I need is specific to a 4 barrel carb. Thank you! Nick
yellow1301 is offline
Old September 22nd, 2017, 06:41 PM
Tedd Thompson's Avatar
Nick if you don't get a answer here drop on down to the vintage forum and ask there . several members there have a Hollander catalog and may be able to cross reference over to a earlier or later year that would work. I'm thinking a late 56 may work with a little adjustment of the long rod(from bell crank to transmission)and would give you more options.... Tedd
Tedd Thompson is offline
Old September 22nd, 2017, 06:46 PM
Moved to Vintage. Good luck in your search.
oldcutlass is online now
Old September 23rd, 2017, 09:00 AM
yellow1301's Avatar
Thank you for the suggestions and thank you for moving my request to the Vintage section. Nick
1k442
April 28th, 2020 06:33 PM
1k442
September 14th, 2016 07:16 PM
Rick67OldsVert
October 20th, 2014 03:14 PM
aliensatemybuick
November 14th, 2011 07:01 PM
granddaddy-O
May 23rd, 2008 08:27 AM
Quick Reply: 57 or 58 carb to bellcrank to transmission linkage
