56 ignition ballast wire removal
Hey guys, I have a Pertronix electronic ignition swap for my 56. Want to remove the ballast wire that goes on the coil, how far in the system is it wired? Is it only ballast on the hot side of the coil? And is it just in the engine bay or both sides of the firewall connector?
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Ah so it's not like the later cars were it actually has a ballast wire? The car is getting delivered to me on Monday do I've still yet to look at it properly. So the wiring is 12 volts and runs one if these as stock:
http://www.hot-spark.com/Hot-Spark%2...20Resistor.jpg.
Just remove the resistor basically and leave the wiring alone?
www.hot-spark.com/Hot-Spark%20Ballast%20Resistor.jpg.
![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
All you have to do is put both wires on the resister on the same terminal. You can leave the resister mounted and I doubt anybody would ever notice both wires are on the same terminal and it would look stock if that matters to you.
Yes I do plan on getting a manual, but don't currently have one.
Ok I'll check with a mulitmeter then on either side of the resister. This is a much simpler way of doing it and being able to remove it rather than trace the wire back and replace the wiring.
Thanks for that, can't wait to get started.
I don't plan on going back to points ![Cool](https://classicoldsmobile.com/forums/images/smilies/cool.gif)
Every car I've put electronic ignition on has always ran better and started better, even if there was no actual problem with points set up, the electronic has always made an improvement. I've always read stuff online with people saying the new electronic stuff has packed up after a while and that it's worth keeping the points set up and tools in the trunk but personally I've not had an issue. And with that comment I'm sure this one will pack up after 100 miles and leave me stranded somewhere!
I don't have the resister on my 54 and don't carry a set of points either. There has always been a lot of debate here on Pertronix vs points. I come down on the side of the Pertronix. No more miles than I put on my car I am sure points would be fine. I have had a Pertronix in my boat for years and no problems.
I had one in my Land Cruiser till the unit fried and left me in a nasty spot 4 wheeling.I didn't have the points in the glove box but did have my hiking boots and walked three miles out to the road and got a lift home. And that's why Redoldsman and I differ on the merits of the Pertronix, many have gone many miles without problems but when they do happen one tends to remember for a long time...... Tedd
Tedd:
We will probably always agree to disagree until Pertronix leaves me stranded. If it had done to me what it did to you, I would cuss it forever. If it had left me standed in the middle of the lake, I would hate the thing. This is one of those things that I think the numbers are about equal on each side of the issue. I will admit, at the end of the day, points are probably safer since there is no module to go out.
I agree it's 6 of one half a dozen of another. If I had been smarter and left a set of points in the glove box I would have had a short ride rather than a long walk but that's a would of could of thing..... Tedd
ChefDeadpool
December 9th, 2011 04:38 PM
dan2286
February 5th, 2009 06:42 PM
