'56 Heater Fan Resistor
Old February 9th, 2016, 03:37 PM
Frank Ignachuck
ignachuck's Avatar
My heater fan doesn't work on "high".
The shop manual shows a resistor that may be the culprit, but I can't find it.
Any one know where it is located?
Thanks, Frank
ignachuck is offline
Old February 10th, 2016, 02:57 PM
Yellowstatue's Avatar
Look on top of the heater case under the dash. Usually mounted in air flow stream for cooling. Follow wires from fan switch to secret location.
Yellowstatue is offline
Old February 12th, 2016, 07:27 PM
Ozzie's Avatar
You might also check continuity on the switch's high speed position and the wire going to the resistor(s). My wiring diagram shows the low speed using two resistors in series with the high speed using only one of the two used on low.
Ozzie is offline
Old February 13th, 2016, 02:24 AM
Frank Ignachuck
ignachuck's Avatar
Thanks very much Yellowstatue and Ozzie. I just bought a spare switch just in case that's the problem. Finding another resistor might be a challenge. I know it's group 8.852/#3131533.
Frank
Old February 17th, 2016, 02:09 PM
Frank Ignachuck
ignachuck's Avatar
A little warmer here today so I ventured under the dash to find the resistor when I got home and there it is, in the heater box. Clear view of the terminals. Lots of corrosion on the connections. I'll clean them off next warm day and see what happens. I don't want to risk breaking off a brittle wire in the cold.
Thanks again Ozzie and Yellowstatue.
Frank
Old February 17th, 2016, 03:28 PM
Frank Ignachuck
ignachuck's Avatar
By the way, Yellowstatue also answered a similar question back in 2010. Thanks.
I'll have to remember to do a search in the future before starting a new thread.
Frank
Old February 17th, 2016, 06:04 PM
I don't mind re-answering questions, over and over...it keeps me awake.
Old February 22nd, 2016, 02:33 AM
Frank Ignachuck
ignachuck's Avatar
I was able to reach in and clean all the connections. All set now. I wish everything on this car was that easy. Thanks again.
Frank
Old February 23rd, 2016, 06:26 AM
WHIPOLDS's Avatar
Frank - My switch does not work on low but it does on high. Thank you for pointing me in the right direction for a fix.
Rick
WHIPOLDS is offline
Old February 23rd, 2016, 11:42 AM
Eightbanger's Avatar
No high speed on my 53, when I turn it on it glows red...
Eightbanger is offline
Old February 23rd, 2016, 04:03 PM
Frank Ignachuck
ignachuck's Avatar
Here is the thread from 2010 that I referenced above. It may help.
https://classicoldsmobile.com/forums...-resistor.html
Frank
Old February 23rd, 2016, 04:36 PM
Frank
Thank you for that Frank.....I had put this issue on the back burner to get some other bigger jobs done first, then I spotted your thread.
I still need to remove my resistor as you had done and clean the whole thing up and see if that helps, I can't imagine these coils were meant to glow red, get hot perhaps but surely not red, it's a fire hazard and what if a kid ever put their hand in there they'd get seriously burned.
W-27
July 23rd, 2015 07:55 AM
amercer7155
June 13th, 2014 12:10 PM
5998DownUnder
June 9th, 2014 09:35 AM
dan2286
February 5th, 2009 06:42 PM
david adelberg
June 2nd, 2008 06:10 PM
Quick Reply: '56 Heater Fan Resistor
