55 Olds front splash apron
Old July 2nd, 2016, 06:30 PM
Olds Scott's Avatar
Has anyone seen a 55 or 56 with the front splash apron intact? So far every Olds that I have seen has only small pieces remaining or none on the car at all. Fender well splashes are easily to find but the fronts seem to be unavailable. Also does anyone make the stock metal clips that hold these rubber pieces on?
Olds Scott is offline
Old July 2nd, 2016, 07:26 PM
Olds Scott's Avatar
This is the rubber splash that attaches between the front cross member and the radiator support, the sway bar goes thru holes in the right and left sides and is attached to the front frame.
Old July 6th, 2016, 12:42 PM
74 2.8L Capri
DFitz's Avatar
Yours may be different than mine. I have the base Holiday 88, 4-door. I had the entire front end apart, and the car is very original. No one but me has messed with it, and it has been in the family since new.
I have no evidence of any kind of rubber splash in front, anywhere by the sway bar or radiator supports. However, there were remains of a burlap cover over and around the front cross-member that protected the fuel lines to the fuel pump.
If it is what I'm thinking, my front splash is metal. Possibly, yours was missing and someone retrofitted something?
I've enclosed pictures of the front. Let me know if you have any other questions.
Dave
DFitz is offline
Old July 6th, 2016, 05:00 PM
Olds Scott's Avatar
Thanks for responding Dave. The rubber splash shield fits under the fuel line and has holes that correspond with the holes on the front cross member, there is a cut out for the hard fuel line that connects to the rubber fuel line. The splash is in two pieces, each side has a hole that the sway bar goes into. The ends that go up on frame ends that have holes for clips that hold them in place. The front of the splash connects to the radiator yoke in corresponding holes. This produces a splash and air direction wall for the radiator. If you or anyone else is interested in this piece I know someone that has started manufacturing them from old patterns. I know they fit because he brought one over and installed it on my car (his splash is for the 56 Oldsmobile but with some small modification it works on my 55). These splashes are made from masticated rubber like the originals.
Old July 6th, 2016, 10:41 PM
74 2.8L Capri
DFitz's Avatar
It sounds a lot like this is in place of the burlap covering my front cross-member. I'd be interested in a picture of the part and the installation when you have it done.
DFitz is offline
Old July 7th, 2016, 09:04 AM
Olds Scott's Avatar
It will be a little while before installation since I am painting front clip parts right now less the fenders themselves. Will get back to you
Old July 24th, 2016, 05:44 PM
Olds Scott's Avatar
I have pictures now but they are on my phone and need help sending
Old July 25th, 2016, 10:09 AM
74 2.8L Capri
DFitz's Avatar
Sorry, not sure what you mean. Usually I just connect my phone, via a USB cable, to my computer, copy the pictures, then post to the forum. Thanks for trying.
DFitz is offline
Old July 25th, 2016, 06:25 PM
cmpcpro's Avatar
Hey Olds I am interested too if you email or text them to me from your phone I can post them. My number is 818-940-8750
cmpcpro is offline
Old July 31st, 2016, 06:08 PM
cmpcpro's Avatar
Hey guys, here are the pictures from Scott. I've already got a set on order!
File Type: jpeg
cmpcpro is offline
Old July 31st, 2016, 06:12 PM
cmpcpro's Avatar
For some reason the pictures don't want to upload correctly
File Type: jpeg
cmpcpro is offline
Old July 31st, 2016, 06:13 PM
cmpcpro's Avatar
Another
File Type: jpeg
cmpcpro is offline
cmpcpro's Avatar
File Type: jpeg
cmpcpro is offline
Old August 1st, 2016, 05:42 AM
74 2.8L Capri
DFitz's Avatar
Hmm. Thanks for the pictures. Do you have a price on this?
DFitz is offline
Old August 1st, 2016, 01:36 PM
cmpcpro's Avatar
They are $45 for the set
cmpcpro is offline
Old August 2nd, 2016, 09:00 AM
Tedd Thompson's Avatar
First time in all my years playing around with a 55 that I have see what that part looks like when complete, most are all gone or just a piece or two left. Learn something new every day on this site.... Thanks ...Tedd
Tedd Thompson is offline
Old August 2nd, 2016, 11:18 AM
Olds Scott's Avatar
Nice thing about this rubber piece is that is can be installed from under the car.
Old August 2nd, 2016, 11:20 AM
Olds Scott's Avatar
It also gets more air thru the radiator.
Old August 2nd, 2016, 12:09 PM
74 2.8L Capri
DFitz's Avatar
Scott,
I tried to PM you, might have gone through, might have disappeared.
I would like details on how to get a set.
Thanks very much, Dave
DFitz is offline
Old August 2nd, 2016, 12:11 PM
cmpcpro's Avatar
Originally Posted by DFitz
Scott,
Hey Dave,
I am heading over there in a couple days to get my set, what year do you have? If you are okay with the $45 I can ask him to put a set together for you. He is having to make mine I guess he didn't have any in stock at the moment.
cmpcpro is offline
Old August 2nd, 2016, 11:30 PM
74 2.8L Capri
DFitz's Avatar
Originally Posted by cmpcpro
Hey Dave,
Yes please. I have a '55. If you could PM me the payment info, and address to send it, that would be great. That way I can also send my mailing address.
Thanks very much. Dave
DFitz is offline
Old August 3rd, 2016, 11:01 AM
74 2.8L Capri
DFitz's Avatar
Scott,
Thanks very much, got your PM. Don't know why, but the web site won't let me PM or answer you either. I just talked to Clifford and he's got me all set.
Thanks, Dave
DFitz is offline
Old August 3rd, 2016, 11:02 AM
74 2.8L Capri
DFitz's Avatar
Hey Dave,
Thanks, but I called him directly and Clifford has me all set. Appreciate the offer.
Dave
DFitz is offline
Old September 15th, 2016, 10:33 PM
74 2.8L Capri
DFitz's Avatar
To everyone with 54-56 Olds.
I installed the front aprons today. This is a masticated rubber piece that is made from the same material as the fender well seals above the A-arms. These also use the same push in clips as the fender seals.
2 pieces, left and right. There is a hole that the sway bar slides into, and the back is pinned up against the front of the cross member. There are 1/4" holes in the front of the cross member. Anyone ever wonder what these were for? They are for the front apron pieces. The front of the piece goes on the front side of the lower radiator mount. They fold around the bottom and front of the radiator mount.
You'll have to remove both ends of the sway bar, and jack the car to get to it from underneath, but not too bad. It took me about 3 hours, and I'm slow.
The outboard end of the flaps lay flat on the top of the frame rails just outboard of the radiator mount. I had to remove a radiator recovery tank on the passenger side, same spot as the windshield washer reservoir, and the battery tray on the driver's side to get at the top of the rails.
These seem to be long lost parts that very few know about because of the age and deterioration of the original parts. If anyone is having cooling problems, this should also help direct more air through the radiator.
CMCPRO, Olds Scott, and I have contact info for the guy making the parts if anyone wants any.
Pictures above. Dave
DFitz is offline
Old September 16th, 2016, 09:22 AM
I'm wondering if this was a AC option to aid in cooling.I know most AC cars had a shroud added for that reason.... Tedd
Old September 16th, 2016, 10:47 AM
Rocketowner's Avatar
Tedd, I bet it was only on cars with factory air, because I don't think my '55 had that on it , and it was the most original car that I have ever seen, with only 38,000 miles and garage kept from the day it was new. Larry
Rocketowner is offline
Old September 16th, 2016, 11:04 PM
74 2.8L Capri
DFitz's Avatar
Well, the guy that made the parts, said that this was on all Olds, even my base model.
I have to say, I found the old push pins in the holes in the lower radiator frame and cross member, and I found the remains of some burlap around the pins. Cliff said that the rubber part had a burlap like twine or reinforcement in the middle of 2 layers of the rubber sheet.
The evidence on mine leads me to believe Cliff, and that this part was on all Olds. He included a sheet from an Olds manual that detailed the part. He also said that, back in the day, he was a service tech on these cars, and remembers the parts.
As I've said before, this car has been in my family since new and can guarantee that it has not been messed with. Since my base model, 55 4-door Holiday 88 had the apron, my bet is they all did. Kansas City built, sold to my grandmother, who lived in Independence, MO--home of the car till 1982. Then my cousin in Wichita--who didn't do anything to it, then me in 1988.
Not unlike the mythical starter shield.
DFitz is offline
Old September 19th, 2016, 03:04 AM
Frank Ignachuck
ignachuck's Avatar
My 56 has factory air and no signs of a rubber splash shield anywhere. It has a radiator shroud and the metal splash apron. And the above mentioned hunk of burlap.
ignachuck is online now
Old September 19th, 2016, 08:22 AM
74 2.8L Capri
DFitz's Avatar
Yes, that's it. That hunk of burlap is the remains of the splash. Initially I thought like you did, mine was metal, and not rubber. The metal shield is at the bottom of and in front of the radiator, right? The rubber splash is in a different spot. It is from the bottom of the radiator mount, back to the front of the crossmember. It closes off the gap between the radiator and crossmember.
That burlap is what's left. It was sandwiched in between, the middle of, 2 layers of rubber mat.
DFitz is offline
Old September 20th, 2016, 10:14 PM
cmpcpro's Avatar
What is the metal splash apron?
cmpcpro is offline
Old September 21st, 2016, 03:14 PM
  #31
74 2.8L Capri
DFitz's Avatar
I'm guessing you mean the metal shield behind the bumper.
DFitz is offline
Old September 21st, 2016, 03:20 PM
  #32
cmpcpro's Avatar
I don't know, the paragraph I quoted had it there and I was curious what he was referring to.
cmpcpro is offline
Old September 21st, 2016, 03:33 PM
  #33
There is a shield/ pan that helps direct air to radiator and plugs the hole that would be there if something wasn't there.... Not sure that makes sense but that is what it does.... Tedd
Old September 21st, 2016, 03:48 PM
  #34
74 2.8L Capri
DFitz's Avatar
Of course it makes perfect sense! There are actually 2 shields, the one in this picture, and a smaller one bolted to the aft, top of the bumper.
Actually, if you look closely, this is a good place to describe the spot where the apron goes. Look at the above picture. See the front of the cross member? The rubber apron goes between that, and the bottom of the lower radiator mount. It closes off that area between where the front engine mount is and the radiator support.
DFitz is offline
Old September 22nd, 2016, 12:48 PM
  #35
Frank Ignachuck
ignachuck's Avatar
^^^^^Yep, that's the metal shield, and an excellent description of all the parts we've been talking about. Thanks!
BeenThere
August 17th, 2018 01:17 PM
ben442
March 28th, 2016 02:12 PM
cheven
June 23rd, 2014 07:28 PM
69442murph
May 26th, 2014 09:42 AM
navvet
August 22nd, 2011 07:08 PM
Quick Reply: 55 Olds front splash apron
