1957 Oldsmobile Timing Cover
Old December 24th, 2023, 06:04 PM
dangulo4's Avatar
1957 Oldsmobile 88 Timing Cover
Hey Friends,
1957 Oldsmobile 88
for context, no factory AC or power steering.
It’s been a lot of staring and asking my self what the heck is going on and how did I get here… LOL! So here it goes, it all started with an oil change that led to dropping the pan and then, removing the radiator… (on a separate thread).
I decided to remove the timing cover… why, I don’t know but felt like I had to. Overall not a hard job since I have both the oil pan removed and radiator removed.
My first question, anything that I should be paying attention, aside from any obvious oil leaks, broken timing chain Luckily I don’t see a broken timing chain.
Second question, is there a trick to replace the oil seal that is located on the timing cover? The shop manual calls for a special tool but feel like theres a way without the tool called out?
In the meantime, I am soaking the cover in parts cleaner, and used a can of engine cleaner.
Below is some of the carnage that occurred today…
dangulo4 is offline
Old December 24th, 2023, 08:22 PM
Phantom Phixer
Charlie Jones's Avatar
Grab the chain halfway between the sprockets.
If you can move it more than 1/4 inch either way it's time to replace the chain and sprockets.
The seal might be pressed in with a large socket of the right size.
A press is preferrable to hammering it in.
Charlie Jones is online now
Old December 25th, 2023, 06:34 AM
Tedd Thompson's Avatar
Are you looking for a problem or just cleaning before reassemble? Might have been easier to just pull the engine, clean the engine on a stand and get after the firewall and undercarriage while it's out in the open, just a thought...Tedd
Tedd Thompson is offline
Old December 25th, 2023, 12:02 PM
dangulo4's Avatar
Thanks and will check the play on chain. Per the shop manual doesn’t look like a hard job to replace.
Yes pulling engine did cross my mind but knowing the budget wasn’t there for a full rebuild, this is as far as I want to go for the moment. We shall see as I keep digging into the engine.
dangulo4 is offline
Old December 25th, 2023, 01:22 PM
Sugar Bear's Avatar
Nice work on the cleanup. Are you going into the valve covers and rocker shafts for cleaning? At a minimum confirm that the oil returns in the heads are clear. After seeing the oil pan it probably needs to be done.
Keep us updated...
Sugar Bear is offline
Old December 26th, 2023, 09:43 AM
74 2.8L Capri
DFitz's Avatar
While you are there.....it's just a few bolts away, I'd replace that front engine mount as well. Mine was as caked as yours and had completely failed. Available from Fusick.
DFitz is offline
Old December 26th, 2023, 06:40 PM
dangulo4's Avatar
@Sugar Bear I did plan on changing valve cover gaskets but didn’t think of cleaning the rocker shafts, will add to list Thanks
@DFitz I did spend some time today removing the motor mount and learned that there were two different mounts, one for cars with factory AC and one with no AC. Un fortunately Fusik did not carry non AC mount. On bright side, Steele rubber does service non AC mounts what they call “Revulcanization Only” https://www.steelerubber.com/motor-m...ice-25-0073-11
This is more expensive but it is what it is…
Question for you Gents - Prior to removing the timing gear, I have set the engine at TDC by aligning the sprockets at the 12 o’clock position and confirmed that the #1 piston is visible by removing spark plug. Does it matter if the engine is at compression or exhaust stroke since I’m not removing the distributor? Also is there a special tool that helps you align pointers aside from eye balling which is what I have done. Lol
1st pic is showing the sprockets aligned at 12 o’clock position and 2nd is prior to removing motor mount in case any one was interested what non AC mount looks like..
dangulo4 is offline
Old December 26th, 2023, 06:47 PM
74 2.8L Capri
DFitz's Avatar
Making progress. Looking good.
DFitz is offline
Old December 26th, 2023, 08:25 PM
Sugar Bear's Avatar
It doesn't matter how the marks are aligned IF and only IF they go back the same way AND the distributor isn't touched. I don't know the factory gear alignment on this generation for TDC on the compression stroke, another member will though.
Old December 31st, 2023, 06:38 PM
dangulo4's Avatar
Spend more time cleaning this front end while I wait for some parts. But here is where I at.
dangulo4 is offline
Old December 31st, 2023, 06:56 PM
Sugar Bear's Avatar
NICE work, looks great!
Mark21
May 2nd, 2023 03:50 PM
Timothy Davenport
April 17th, 2020 03:06 PM
Bubbasred69
June 23rd, 2019 09:17 PM
Ultra Tweaker
May 22nd, 2019 08:40 PM
http
April 26th, 2013 09:58 AM
Quick Reply: 1957 Oldsmobile Timing Cover
